Is DGSource (from the DG NV Tools) incompatible with KNLMeansCL or something?! DGSource suddenly gives me an error about not being able to create a video instance of sorts.
This is a real pain, and DGSource is really the only frame-safe processor I know (which actually *is* frame safe, and not just claims so).
DGDecNV uses the video decoder chip on the graphic card, thus needs to set up the graphic card in one way to get access to it.
KNLMeansCL uses the computing units on the graphic card, thus needs to set up the graphic card in another way to get access to it.
I could imagine that both ways are mutually exclusive or at least hard to separate from each other. So I wonder if Donald Graft knows more about such details. You may have to ask him in his own forum, though. He can be ... not as sociable as others.
__
It is already being discussed: DGDecNV and KNLMeans under Win10_x64 – it may work under Windows 8.1 instead; in this case, it's a driver issue and Microsoft or Nvidia are more probable to be blamed than AviSynth and its plugin developers.Last edited by LigH.de; 29th Apr 2016 at 17:34.
Incompatible hardware ports
By gt6 in forum Newbie / General discussionsReplies: 17Last Post: 19th Aug 2015, 10:17 -
Are DVDs Incompatible Between Mag Recorders?
By Novice20 in forum Newbie / General discussionsReplies: 7Last Post: 28th Jul 2015, 20:12 -
Incompatible signal :mad:
By vonz in forum MediaReplies: 12Last Post: 27th Jul 2013, 10:52 -
Incompatible discs
By caleb89sw in forum DVD & Blu-ray RecordersReplies: 17Last Post: 2nd Jul 2012, 04:02 -
textsub incompatible with avisynth 2.5?
By icieling in forum DVD RippingReplies: 1Last Post: 1st Aug 2011, 15:56
