While I was trying to sync subtitles to an mkv file, I found that each time I played the same file, audio seemed to shift a few seconds. So the same sentence was spoken at 01:06:24, the next at 01:06:22 and then again at 01:06:26.
That makes it impossible to sync subtitles and audio. At first it seemed audio was off only in Subtitle Workshop 2.51, but I later found it also happened in MPC-HC (Nightly) 1.7.5.195 (0d2d2d2), with FFmpeg compiler MinGW-w64 GCC 4.8.2.
How is it possible that audio is not reproduced in exactly the same manner each time? I tried looking up this phenomenon on this forum, but I didn't find it, which may have to do with the fact I didn't use the right search terms.
Anybody any idea?
Cheers,
sandokanfirst
Does it only happen to this mkv?
No audio sync issues?
Try also play with vlc media player and see if you get similar issue.
And try sync it with subtitle edit. -
Thanks, Baldrick.
There are no audio sync issues, so it seems that the movie is sometimes a bit faster, and sometimes slower. I'll try and see what happens with VLC. It happens with a few more movies (only mkv). It's not a big deal, I'm just curious what can cause the phenomenon.
I'll also try and use Subtitle Edit to see what happens.
Cheers,
sandokanfirst
Posting Permissions
no sound with mp4 files in subtitle workshop
By flannob in forum Newbie / General discussionsReplies: 11Last Post: 19th Feb 2016, 10:29 -
MKV and Subtitle Workshop
By nogas19 in forum SubtitleReplies: 1Last Post: 27th Jun 2015, 10:32 -
Subtitle Workshop MP4/MKV video preview problem.
By sinsinati in forum SubtitleReplies: 3Last Post: 4th Nov 2014, 22:19 -
Subtitle Workshop not showing mkv files during preview
By tuna1013 in forum SubtitleReplies: 27Last Post: 26th Jun 2014, 13:57 -
dissonance between timing in subtitle workshop an vlc player
By JetBlack in forum SubtitleReplies: 1Last Post: 28th Feb 2013, 11:37
