OK I have film on a dv cam. I extracted a 2 min clip of still shots in a single avi file (no memory cards). I want to take the avi and extract images out of to edit, print, etc as a single picture. There's roughly 10 pictires I need to extract but I'm having a little difficulty doing it. I have Adobie Premiere 6, Ulead Video Studio 4SE, amongst various other software. Can some one helpe me on this? Thanks
Open the AVI in virtual dub. video...copy to clipboard. Paste into your favorite image editor and save to disk.
Alternatively, you can also save an image sequence in virtual dub (file...save image sequence), but that saves all sequential frames in your file (dozens, hundreds, thousands, so this can get huge).As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
In Premiere 6, the Export function in the file menu has a Frame option. Whichever frame is currently showing will be saved as a .bmp file.
My God you guys are kool. I should have seen that export frame option and I would like to compare virtuadubs quality with adobe so thank you both for your help. Take care and thanks again
How to extract audio from .vob files
By webadm in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2012, 22:28 -
How to Extract Audio From WMV Files?
By devilcoelhodog in forum AudioReplies: 10Last Post: 23rd Jun 2009, 11:32 -
How to Extract Subtitles from ratDVD Files?
By devilcoelhodog in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2009, 08:24 -
extract .iso files
By avextraxjp in forum Newbie / General discussionsReplies: 8Last Post: 1st Jun 2008, 02:49 -
How to extract hardsubs from .avi files?
By kehn in forum SubtitleReplies: 4Last Post: 25th Jul 2007, 08:30
