Hey, so im currrently trying to stream my windows desktop using ffmpeg into a raspberry pi running ffserver.
The client software im using needs to use RTSP, however i cannot connect to the stream no matter what i try.
I even used VLC in the messages it just says it cannot connect to the stream.
Any help would be greatly appreciated!
Im attempting to access the stream with rtsp :// 169.254.70.227 :8544/test.flv, as soon as i do it stops the ffmpeg feed
FFserver conf
FFmpeg feedCode:RTSPPort 8544 HTTPPort 8090 # Port to bind the server to HTTPBindAddress 0.0.0.0 MaxHTTPConnections 2000 MaxClients 1000 MaxBandwidth 10000 # Maximum bandwidth per client # set this high enough to exceed stream bitrate CustomLog - # Remove this if you want FFserver to daemoni$ <Feed feed1.ffm> # This is the input feed where FFmpeg will send File ./feed1.ffm # video stream. FileMaxSize 100000K # Maximum file size for buffering video ACL allow 192 .168.0.8 ACL allow 192 .168.0.17 ACL allow 169 .254.70.227 ACL allow 169 .254.9.29 ACL allow 169 .254.165.231 ACL allow 10 .14.2.197 ACL allow 192 .168.0.13 ACL allow 10 .14.2.197 ACL allow 192.16 8.0.13 ACL allow 192.1 68.1.3 ACL allow 192. 168.1.4 ACL allow 192 .168.1.2 </Feed> <Stream test.flv> # Output stream URL definition Format rtp Feed feed1.ffm NoAudio # Video settings VideoCodec libx264 VideoSize 720x576 # Video resolution VideoBufferSize 2000 VideoFrameRate 30 # Video FPS # Parameters passed to encoder AVOptionVideo qmin 10 AVOptionVideo qmax 42 PreRoll 15 StartSendOnKey MulticastAddress 224 .124.0.1 MulticastPort 5000 MulticastTTL 16 VideoBitRate 450 # Video bitrate </Stream> <Stream status.html> # Server status URL Format status # Only allow local people to get the status ACL allow localhost # Only allow local people to get the status ACL allow localhost ACL allow 192.168. 0.0 192.168. 255.255 </Stream> <Redirect index. html> # Just an URL redirect for index # Redirect index.html to the appropriate site URL http ://www. ffmpeg .org/ </Redirect>
FFserver outputCode:ffmpeg -rtbufsize 2100M -f dshow -r 29.970 -i video=screen-capture-recorder -c video=screen-capture-recorder.flv http :// 169 .254.70.227:8090/ feed1.ffm
FFMpeg outputCode:configuration: --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-nonfree libavutil 55. 22.101 / 55. 22.101 libavcodec 57. 35.100 / 57. 35.100 libavformat 57. 34.103 / 57. 34.103 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 44.100 / 6. 44.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 /etc/ffserver.conf:48: Setting default value for video bit rate tolerance = 112500. Use NoDefaults to disable it. /etc/ffserver.conf:48: Setting default value for video rate control equation = tex^qComp. Use NoDefaults to disable it. /etc/ffserver.conf:48: Setting default value for video max rate = 20744848. Use NoDefaults to disable it. Wed Apr 27 10:33:46 2016 FFserver started. Wed Apr 27 10:33:46 2016 224.124.0.1:5000 - - "PLAY test.flv/streamid=0 RTP/MCAST" Wed Apr 27 10:33:46 2016 [rtp @ 0x13d4660]Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. Wed Apr 27 10:33:49 2016 169.254.165.231 - - [GET] "/feed1. ffm HTTP/1.1" 200 4175
Code:Stream mapping: Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264)) Press [q] to stop, [?] for help [swscaler @ 000000000252f5e0] Warning: data is not aligned! This can lead to a speedloss av_interleaved_write_frame(): Unknown errortime=00:00:05.00 bitrate= 249.0kbits/s speed=0.393x Error writing trailer of http: //169. 254.70.227:8090/feed1.ffm: Error number -10053 occurredframe= 204 fps= 15 q=26.0 Lsize= 164kB time=00:00:05.03 bitrate= 266.9kbits/s speed=0.365x video:155kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 5.475512% [libx264 @ 00000000025187e0] frame I:1 Avg QP:34.24 size: 32151 [libx264 @ 00000000025187e0] frame P:59 Avg QP:27.14 size: 1807 [libx264 @ 00000000025187e0] frame B:144 Avg QP:32.16 size: 168 [libx264 @ 00000000025187e0] consecutive B-frames: 4.9% 2.0% 2.9% 90.2% [libx264 @ 00000000025187e0] mb I I16..4: 26.0% 23.1% 50.9% [libx264 @ 00000000025187e0] mb P I16..4: 1.9% 1.6% 1.1% P16..4: 4.3% 0.6% 0.4% 0.0% 0.0% skip:90.2% [libx264 @ 00000000025187e0] mb B I16..4: 0.2% 0.1% 0.1% B16..8: 3.1% 0.1% 0.0% direct: 0.1% skip:96.3% L0:26.0% L1:73.5% BI: 0.5% [libx264 @ 00000000025187e0] final ratefactor: 24.13 [libx264 @ 00000000025187e0] 8x8 transform intra:31.8% inter:47.1% [libx264 @ 00000000025187e0] coded y,u,v intra: 28.1% 8.2% 6.3% inter: 0.6% 0.2% 0.1% [libx264 @ 00000000025187e0] i16 v,h,dc,p: 30% 63% 6% 1% [libx264 @ 00000000025187e0] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 16% 63% 1% 0% 0% 1% 0% 3% [libx264 @ 00000000025187e0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 39% 15% 2% 2% 3% 4% 3% 4% [libx264 @ 00000000025187e0] Weighted P-Frames: Y:0.0% UV:0.0% [libx264 @ 00000000025187e0] ref P L0: 66.3% 13.1% 16.9% 3.6% [libx264 @ 00000000025187e0] ref B L0: 66.6% 29.7% 3.8% [libx264 @ 00000000025187e0] ref B L1: 91.7% 8.3% [libx264 @ 00000000025187e0] kb/s:191.78 Conversion failed!
I'm not sure if you can use ffserver in windows.
I would try stream with VLC instead. https://wiki.videolan.org/Documentation:Streaming_HowTo/Command_Line_Examples/
I use it and it works fine with different protocols. -
Does your raspberry Pi have all the required codecs?Code:
Ffserver
By Ansii in forum Video Streaming DownloadingReplies: 3Last Post: 19th Apr 2016, 17:49 -
Stream from RTMP to Nokia 72 (RTSP) on home network
By Wader8 in forum Video Streaming DownloadingReplies: 13Last Post: 24th Nov 2014, 01:32 -
RTSP streaming: what does "RTSP/1.0 457 Invalid Range" mean exactly?
By ParkerKemp in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2014, 05:24 -
Help streaming /dev/video0 over http using VLC or ffserver/ffmpeg
By limiteddi in forum Video Streaming DownloadingReplies: 0Last Post: 26th Dec 2013, 22:22 -
How to split a rtsp stream in audio and video track
By mobail in forum Newbie / General discussionsReplies: 2Last Post: 22nd Sep 2011, 09:39
