I'm using MP4Tools by EmmGunn to convert m2ts files to mp4 files. I don't want the output filename to be the input filename + mp4 extension.
Is there a way to specify the output filename?
Thanks in advance.
I don't think so.
I would try find a batch renamer software if you want to rename lots of files.
My mkv files will not load into mp4tools
By dunebuggy in forum MacReplies: 7Last Post: 3rd Mar 2016, 03:55 -
MP4tools Registration code.
By winterds in forum MacReplies: 3Last Post: 5th Oct 2015, 18:11 -
MP4Tools Pass thru sync issues
By bellevik in forum MacReplies: 2Last Post: 16th Apr 2012, 03:47 -
Join m4v splitted with mp4tools?
By Cartman in forum Video ConversionReplies: 2Last Post: 10th Jan 2012, 16:12 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52
