  1. Hi
    I'm still learning so bear with me. There is something I'm a bit confused about. I've used mkvmerge to remux an MPEG-TS file to MKV and I see there is a huge decrease in file size. I thought remuxing was just changing containers as nothing is being re-encoded, or have I got it wrong?
    I also noticed the MKV output file says the bitrate is decreased, am I losing quality?
    I've included the mediaInfo details for both files.
    MPEG-TS file: 5.71 GB
    MKV file: 3.69 GB
    Does this look right?
    Format                      : MPEG-TS
    File size                   : 5.71 GiB
    Duration                    : 43mn 54s
    Overall bit rate mode       : Variable
    Overall bit rate            : 18.6 Mbps
    Video
    Menu ID                     : 1 (0x1)
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : High@L4
    Format settings, CABAC      : Yes
    Format settings, ReFrames   : 2 frames
    Format settings, GOP        : M=1, N=15
    Codec ID                    : 27
    Duration                    : 43mn 54s
    Bit rate mode               : Constant
    Bit rate                    : 17.8 Mbps
    Width                       : 1 920 pixels
    Height                      : 1 080 pixels
    Display aspect ratio        : 16:9
    Frame rate                  : 25.000 fps
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Interlaced
    Scan order                  : Top Field First
    Bits/(Pixel*Frame)          : 0.343
    Stream size                 : 5.31 GiB (93%)
    Color range                 : Limited
    Color primaries             : BT.709
    Transfer characteristics    : BT.709
    Matrix coefficients         : BT.709
    Audio
    Menu ID                     : 1 (0x1)
    Format                      : MPEG Audio
    Format version              : Version 1
    Format profile              : Layer 2
    Codec ID                    : 3
    Duration                    : 43mn 54s
    Bit rate                    : 384 Kbps
    Channel(s)                  : 2 channels
    Sampling rate               : 48.0 KHz
    Compression mode            : Lossy
    Stream size                 : 121 MiB (2%)
    Language                    : English
    Format                      : Matroska
    Format version              : Version 4 / Version 2
    File size                   : 3.69 GiB
    Duration                    : 43mn 54s
    Overall bit rate mode       : Constant
    Overall bit rate            : 12.0 Mbps
    Writing application         : mkvmerge v8.2.0 ('World of Adventure') 64bit
    Video
    Format                      : AVC
    Codec ID                    : V_MPEG4/ISO/AVC
    Duration                    : 43mn 54s
    Bit rate                    : 11.4 Mbps
    Nominal bit rate            : 17.8 Mbps
    Frame rate mode             : Constant
    Color space                 : YUV
    Bit depth                   : 8 bits
    Bits/(Pixel*Frame)          : 0.220
    Stream size                 : 3.50 GiB (95%)
    Default                     : Yes
    Forced                      : No
    Audio
    Format                      : MPEG Audio
    Codec ID                    : A_MPEG/L2
    Codec ID/Hint               : MP2
    Duration                    : 43mn 54s
    Bit rate                    : 384 Kbps
    Stream size                 : 121 MiB (3%)
    Language                    : English
    Default                     : Yes
    Forced                      : No
  2. Probably something is wrong. Typical transport stream overhead is usually about 5-8%. That size is too small
    Even mediainfo reports video stream size is wrong 3.5GiB vs. 5.31GiB
    But a rare possibility is that your source TS was heavily padded (filler muxing for CBR) - in that case mediainfo is incorrect . You can demux both videos and compare the stream sizes to be sure
  3. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    If MKVMerge did not give any error warnings then I would say it is just the padding and inefficiency of .TS, assuming this is a broadcast source. MKVMerge is usually pretty good at giving errors on stream errors and irregularities. So if there were no errors, and the MKV plays well then I would think it's fine.
    Also the new MKV lists
    The nominal is the same bitrate as the .TS. Broadcast streams have to fill the entire available bandwidth, even if it's with filler blank data. I've had decent luck with simply compressing MPEG2/.TS videos with 7zip giving me ~10% savings.
    MKVMerge certainly is not re-encoding anything.
  4. Thank you guys. No errors were reported in mkvmerge during remuxing. This was a satellite feed straight from the truck intended for the broadcaster, if that makes any difference.
    'Nominal bit rate' was going to be my next question, but @KarMa has cleared this up.
  5. The way to check it is to demux both and compare the stream size (e.g. tsmuxer for the ts and gmkvextract for the mkv). For example mkvmerge might have aborted on an error, truncating the stream (it doesn't necessarily have to report the error)
    It's very suspicious because that's massive amount of padding. 5-8% is typical. That is 10x the usual amount.
    Also, there might be other streams that mediainfo isn't reporting to make up that physical size
  6. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Should update mkvmerge, just because.
