Good day
Some bad news
Transcoded h264 to prores HQ with ffmpeg 64 bit(zeranoe static 64 bit) on windows 7 64bit. Core I 3 processor with 16g ram and 2TB HDD drive. The h264 file was 2hours 33 minutes long and was shot in 50 fps interlaced standard quality on a sony hdr 540pj.
The output file was going to be about 220gb of size.
After about an hour of transcoding the computer the computer was emitting smoke and everything was dead inside. Everything smelled burned and the computer was dead inside.
Was this due to poor ventilation inside the pc or was the computer simply not designed for such a workload ?
Results 1 to 18 of 18
Any desktop computer should be able to withstand 100 percent CPU load indefinitely. That requires sufficient cooling of everything inside and sufficient air flow through the case. CPUs are pretty well protected today. They will slow down, even halt, when they overheat. I suspect your power supply burned out, taking the rest of the computer with it. Cheap power supplies often can't put out half the power they claim.
So even if the cpu was hot(let's say from poor ventilation) it should have shut down automatically?
How is it possible that a cpu can destroy a psu? Aren't they designed for such things? Can cpu draw that much power?
Thanks for your replies.
Is there a brand of psu that is considered good in terms of being able to deliver what it says it can and can this be tested in advance before connecting to your compuiter? -
corsair, seasonic and evga brands are all i use. never had a problem with those. get a psu with plenty of spare wattage for the cpu/gpu combo you have. you can google "psu ratings" and find the best of 2016
Most any name brand PS of 500 W or so should be OK. But even name brand PS's can have a flaw.
It's likely that the CPU had nothing to do with the PS failure, if that is what happened.
And that does seem likely. Not many components in a PC can emit smoke except a PS.
In no particular order, name brand PSs, Thermaltake, Power and Computing, Antec, Corsiar, Coolermaster, Seasonic and many more.
Occasionally, a PS failure doesn't destroy all of the PC components. If you have another PS available for replacement, you might be lucky and just the PS died.
You would want to take a close look at the motherboard, both sides, and internal components and look for signs of burn marks or overheating. Good luck. -
With a Core i3 you probably don't need anywhere near a 500 watt PSU. Unless you have a power hungry GPU. My i5 2500K has been running on a 430 watt Corsair PSU for years.
Just checked the pc:
Psu TT-350NL1NK thermaltake
350 watt max
Graphics card
gt 730
2 hard drives not sure if they were in raid configuration -
A common reason for a psu failure is that the psu's fan stops working, noboby notices and and the psu overheats. If it is a noname psu with no built in safeties it can take out the motherboard. On top of that if the psu's fan is the only air extracting fan in the case it can damage components before the complete failure.
http://images10.newegg.com/BizIntell/tool/psucalc/index.html?name=Power-Supply-Wattage-Calculator
518 watts recommended
For the pc
Shite -
One final question: does ups's do voltage regulation? We have as a common problem in south africa over voltage supply sometimes going as high as 260 volts.
Usually not, depends on the type of ups. They should all have a surge protection. In this situation I would use a dedicated voltage regulator though.
edit for clarification : you can read on the different types of ups here. The cheapest and most common standby ups don't do voltage regulation, if you want that feature you need a Line Interactive UPS or better.
http://www.apc.com/support/index?page=content&country=ITB&lang=en&locale=en_US&id=FA157448Last edited by ackboo; 26th Apr 2016 at 19:55.
Processor
Core I 3
Motherboard
Gigabye
H81M-S2PH
Ram
2 x 8gb crucial GX64
Graphics card
GV-,N730 gigabyte
Chassis
Yama midi atx
Psu
Thermaltake TT-350NL1NK
Harddrive
Seagate baracuda 7200 rpm
2000 gb
There is a second seagate baracuda 80 gb 7200 rpm I don't know if it was used though its powe connector was badly burned. This drive never showed in windows only the 2TB one.
Optical drive
Dvd writer and blue ray rom its rarely used
Super multi dvd writer
Model gh24db8Last edited by oduodui; 26th Apr 2016 at 18:00.
ffmpeg CPU usage
By diprotic in forum Video ConversionReplies: 13Last Post: 19th Apr 2015, 14:40 -
ffMPEG takes too much times, cpu and memory with -subtitles args
By Gouranga Das in forum Video ConversionReplies: 5Last Post: 10th Oct 2013, 02:39 -
How to let ffmpeg run with lower (not lowest) CPU priority?
By pxstein in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2013, 02:16 -
AVCHD transcoding with MultiAVCHD... SLOW (just 30% CPU usage)
By borst_one in forum Authoring (Blu-ray)Replies: 17Last Post: 19th Jan 2012, 11:02 -
Newbie - ffmpeg args for transcoding 1080p to 720p, etc.
By awatelet in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2011, 13:21
