Hi,
I received an subtitle file from my Japanese friend.
It's file extension is .sdb format.
I'd test to play this subtitle and I can't find software player to play this subtitle. (VLC, PotPlayer, ... )
When I search for information from google there were two relevant search results in Japanese companies.
When I view this file in Hexadecimal viewer, I saw the text 'CANVASs SST FMT' in front of file.
It seems like a kind of sst format. I find a solution to convert this sdb file to srt or other formats (srt, smi, .. etc)
Can anyone help?
Can you upload a sdb subtitle? Attach it when you post.
Hello, dear all. Perhaps some links below helps?
---> https://www.dcmp.org/ciy/converting-youtube-to-srt.html
---> http://docs.transifex.com/formats/subtitles/
---> https://en.opensuse.org/SDB:Making_a_video_clip
---> http://canvass.co.jp/global/products/sst_g1/index.html ( subtitling program )
---> https://discussions.apple.com/thread/2051859?tstart=0
---> http://www.doom9.org/mpg/ccguide.htm
If it is kind of subtitle format you are looking for, you maybe can try open / convert using the program below:
---> https://www.videohelp.com/software/Subtitle-Edit
If you fail about converting / opening the file, put it here for download such subtitle, in a way that of all of us can analyse it.
Best regards.
devil (johner)Last edited by devilcoelhodog; 25th Apr 2016 at 16:55.
What format is this video file?
By ahmadalani in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2016, 14:11 -
how can convert dts AUDIO file with 5.1Ch in MKA format to a audio file?
By enable in forum AudioReplies: 4Last Post: 11th Dec 2012, 12:11 -
What's the best file format to use?
By jaccarrino in forum Authoring (DVD)Replies: 14Last Post: 4th Oct 2012, 19:51 -
Which file format to use
By drtanz in forum Video ConversionReplies: 2Last Post: 16th Oct 2011, 14:46 -
Which file format does everyone prefer?
By kamelman in forum Newbie / General discussionsReplies: 11Last Post: 10th Sep 2011, 09:46
