Please dont shoot me down in flames for such a lamens question, but When converting music files am I correct in thinking the higher the bitrate, the better ?
Basically when converting music files to play in M4A format on my iPod, eg from a FLAC file, Using AVS Audio Converter, which I find a great program, its default setting for best quality is 256Kbps but it can be customised to 512.
Will changing this setteing improve the listening quality of the audio track ?
"Improve" is not the right word. When encoding using a lossy codec like AAC/M4A there is always quality loss. The higher the bitrate you choose the less quality is lost. But there are diminishing returns. While you should be able to easily hear a difference between 16 kbps and 128 kbps you most likely won't hear a difference between 256 kbps and 512 kbps. So even though the 512 kbps version is technically better it won't make a difference to you as a human.
Simple question about XAVCS videos
By Jamaika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 12th Jun 2015, 23:16 -
MKV to MP4 simple, and probably dumb question.
By PedgeJameson in forum Video ConversionReplies: 4Last Post: 2nd Apr 2015, 04:31 -
VirtualDubMod (simple?) question about speeding up a portion of a video
By kaosguy in forum Video ConversionReplies: 3Last Post: 3rd Jan 2014, 15:20 -
A simple question on Xmedia Recode
By Digmen1 in forum Video ConversionReplies: 1Last Post: 28th Dec 2012, 20:04 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 04:52
