Hi all
I've got a huge library of music videos in AVI (Xvid) format. Most of these were encoded from VOB files that I ran through VideoRedo first to trim off the first few frames and chop off any credits that appeared at the end. The reason for this is that, when I hit play, I wanted the music to play straight away and not have the several-seconds gap that you tend to get (I used to occasionally play the videos off a projector in a nightclub and had a few embarrassing pauses).
A lot of the files I'm getting now aren't in VOB format anymore so I need a new solution to trim the beginning and end frames. Is there a simple free one that'll allow you to do this (without having to re-encode the video and audio and causing degradation) and will work on multiple formats including MKV and MP4?
Thanks in advance
free one would be avidemux, but it can be a bit buggy, and you have to cut on keyframes
non free ones that are frame accurate (smart render, may encode a few frames around the cutsite depending on where you cut) are videoredo v4, solveigmm video splitter, tmpgenc smart renderer -
Trimming start and end off multiple files
By hapsee in forum EditingReplies: 1Last Post: 7th Feb 2016, 08:26 -
Trimming video from it's end using FFMpeg or Mencoder
By get8p in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2012, 21:12 -
how to author a DVD from the beginning to the end
By michcio in forum User guidesReplies: 3Last Post: 13th Apr 2012, 17:43 -
File has more frames after trimming.
By sambat in forum EditingReplies: 0Last Post: 27th Jul 2011, 07:43 -
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 18:04
