I have VideoReDo TVSuite. It will read *.dvr-ms, mp4, mpg, mpeg, rec, ts, tp, tivo, VOB, VRO, and wtv files.
I need to be able to edit a DVD movie that is copy-protected and edit out some scenes, language, etc. to make it more appropriate for kids.
Can you recommend a program to unprotect and rip to an easy format such as MPEG?
Use DVD Fab (demo mode works fine) or DVD Decrypter (old but still works for most discs) to rip as a VIDEO_TS folder. Then use VOB2MPG to convert the VOB files to one big MPG file. Edit the MPG file and author a new disc.
Or use a background ripper like dvdfab passkey(the free version might work) or anydvd. Then can you use vob2mpg directly from the dvd or import dvd vobs directly in videoredo.
Or... you can leave the movie be and don't show it to the kids if you think it's unappropriate.
"The greatest trick the Devil ever pulled was convincing the world he didn't exist." -
Be sure that if you're working with MPEG-2, and wish to edit and keep the format as such, especially if you want to put it back on DvD after, you should work with a dedicated MPEG editor. What I'm talking about is an editor that would take the MPEG streams, cut, join, crossfade, etc, and only reencode the few frames "at the seams" without touching the other parts. This would be faster, and save you tons of quality (since MPEG-2 is a lossy format).
I don't know of any good free editors that do this, but an excellent MPEG-dedicated editor is from Womble. Also is your VideoReDo, and TMPGEnc MPEG Smart Render. (But the latter two are more linear.)
Or... you can...
Never mind.
I hate VHS. I always did.
Please help - how to rip this? Is it a new format?
By IlMagni in forum Video Streaming DownloadingReplies: 5Last Post: 1st Nov 2015, 15:06 -
Can you Rip DVD to 740 or 1080 format?
By laithmeister in forum DVD RippingReplies: 18Last Post: 9th Feb 2014, 16:10 -
Format Factory 3.3.1 won't let me rip DVD into high quality video
By MR-068 in forum Newbie / General discussionsReplies: 7Last Post: 6th Feb 2014, 14:25 -
Converting Bluray rip to DVD format ?
By HairyToes in forum Newbie / General discussionsReplies: 28Last Post: 31st Dec 2013, 20:41 -
Controlling the format of a DVD rip
By m47 in forum Video ConversionReplies: 1Last Post: 18th Jul 2011, 08:33
