  1. http://www.amazon.com/dp/B01880ROSE?psc=1 I see several devices like this. What i am looking for is a switch that will let me connect 2 or 3 hdmi cameras to a computer so that I can switch around. I want to use 3 cameras to video a school event and upload the performance real time to the web. I need some kind of hardware - maybe this switch - to do it, and then some software as well so that I can fade from one to the other - create smooth transitions. Will this do the trick?
  2. Member DB83's Avatar
    Jul 2007
    That switch will provide you with 3 inputs and one output.
    But you can not directly connect a hdmi output to a computer. You will also need a capture card that has a hdmi input.
    Then you need the streaming software to capture/encode/broadcast. This may do the biz.
    https://obsproject.com/
    Have not used it so can not vouch for it
  3. You probably won't get seamless switching with that device. Every time you switch from one camera to another you'll probably get a loss of signal fora second or so.
    Jan 2007
    television studios, everything is in sync
    with what you are proposing those cameras will not be in sync (frame wise)
    everytime you switch, the capture device will have to re-aquire the signal from that camera
    it is NOT going to be fluid or seamless
    Aug 2006
    This video might interest you: https://www.youtube.com/watch?v=XQ0gOKlkqSg
