Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. I am sure this has been asked before but I have never found a solution. I have a bluray mkv file, no issues, panning is smooth, but when I convert it to dvd NTSC compatible mpeg2, the panning is often jerky and not smooth. The source file is probably PAL so I am sure that might be part of the issue in conversion. I have tried TMPG video mastering works, QMC (quick media converter) and xvid4psp. Any suggestions would be greatly appreciated.
    Try also avstodvd. You can output as dvd or mpeg2 files.
    Post also the video details from the mkv. Use for example mediainfo, open mkv, change to view->text and copy all video details.
  3. General
    Unique ID : 86340287372842535067164299267373676751 (0x40F488D41050542657051F33A63638CF)
    Complete name : C:\Users\pcammara\Desktop\Maryam and Various\April 2016\Two Men Town\Two Men In Town 1973.mkv
    Format : Matroska
    Format version : Version 2
    File size : 1.60 GiB
    Duration : 1h 38mn
    Overall bit rate : 2 319 Kbps
    Movie name : Deux.Hommes.Dans.La.Ville.1973.TRUEFRENCH.BDRip.x2 64-R1
    Encoded date : UTC 2015-10-29 12:44:00
    Writing application : mkvmerge v5.6.0 ('Kenya Kane') built on May 28 2012 06:47:39
    Writing library : libebml v1.2.2 + libmatroska v1.3.0
    Video
    Format : AVC
    Format profile : High@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 14 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 38mn
    Bit rate : 1 633 Kbps
    Width : 720 pixels
    Height : 432 pixels
    Display aspect ratio : 5:3
    Original display aspect ratio : 5:3
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.219
    Stream size : 1.13 GiB (70%)
    Writing library : x264 core 132
    Encoding settings : cabac=1 / ref=14 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1,00:10,00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=18 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20,0 / qcomp=0,60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1,40 / aq=1:1,00
    Language : English
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 1h 38mn
    Bit rate mode : Constant
    Bit rate : 640 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Frame rate : 31.250 fps (1536 spf)
    Compression mode : Lossy
    Stream size : 452 MiB (28%)
    Language : French
    Default : Yes
    Forced : No
    Text
    Format : PGS
    Muxing mode : zlib
    Codec ID : S_HDMV/PGS
    Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
    Default : No
    Forced : No
    You should convert it to NTSC in AVStoDVD.
  5. I used it, not much better, some flicker too. There must be a tweak I have to set. Also, how do you get it to give you 16x9?
    Mar 2008
    edit title/video tab/deselect auto video setup/video aspect ratio
