Simple way to convert DVD VOBs to MPGs for import to Imovie10?
Results 1 to 12 of 12
I found Cinematize among Mac OSX tools, but it appears the maker is out of business and only demo versions are available. Maybe DVDFab DVD Ripper can do DVD to mpg conversion?
Nope.
Maybe mpeg streamclip, open all vobs, use file->save and it shouldn't reconvert. I think...I haven't used it for some years now.Last edited by Baldrick; 20th Apr 2016 at 13:21.
I'll try to clarify as I'm getting my info second hand.
The videos are in two formats, home made DVDs of amateur theatrical performances and others are similar subject VHS tapes converted to MPEG-2.
No DRM involved.
They can be converted again to a MP4 format from either source with a PC version of AVIDemux which IMovie 10 seems to open.
IMovie 10 doesn't seem to recognize either a MPEG-2 or a VOB.
There is a Mac version of AVIDemux that may be able to work and he could skip IMovie10 completely.
That would be my recommendation, though I'm at a loss why IMovie 10 doesn't work. He's more comfortable with IMovie 10, though.
I believe the final format is something that will play on YouTube.
The video editor just needs to be able to cut out sections for YT posting.
Converting to MP4 from a MPEG/VOB then to a YouTube format seems a bit strange to me also.
So I may still need more clarification.
A musician friend of mine had the same problem with an OLD Mac. He could not work with my mpg files that I took straight from a DVD. He emailed me back saying that he had to pay extra to allow his Mac to decode mpeg2? Is that possible? Is that still the case? Diehard Mac people never seem to want to give a straight answer on that. Has a Mac, straight out of the box, ever NOT been able to handle mpeg2/DVD video?
iMovie 10 only imports MP4, MOV, M4V files that are encoded with MPEG-4 (part 2)/AAC or H.264/AAC. Previous version of iMovie had more import options.
MPEG Streamclip can open VOB files, cut out sections, and save as MPEG, or convert to other formats. In order to display MPEG-2 content (i.e. work visually with it), or convert from that, it needs the $20 QuickTime MPEG-2 Playback Component (a plug-in for the now almost obsolete QuickTime v7).
We both know there is no such thing as a “YouTube format”.
YouTube accepts almost anything, and will convert everything anyway.
Thanks, Case. That does answer most of my questions.
I haven't used a Mac in a long time, so was a bit lost.
I was wondering if you have tried the Mac version of AVIDemux?
It seems to output MPEG-4 with the correct attributes for IMovie 10
if he doesn't want to choose the MPEG Streamclip program and plugin.
I did mention to him that YT would likely reconvert, but his VHS based videos are not the greatest quality and a bit of editing,
cropping and filtering would probably improve them, hence AVIDemux and skip IMovie 10.
I still have Mpeg Streamclip installed on an old Powerbook running OSX 10.5.8 Leopard. It is a briliant tool for many kinds of editing and format conversion. The software has not been updated for some years, so I would not know where compatability with OSX ends? One needs the QT mpeg2 component installed in order to work with VOB and mpeg2 files (as mentioned above).
MPEG Streamclip here too.
How can I boost volume on my mpegs/vobs
By David Cooper in forum Newbie / General discussionsReplies: 8Last Post: 17th Dec 2015, 17:09 -
Audio problem when converting VOBs in VOB2MPG
By StratasFan in forum Video ConversionReplies: 6Last Post: 30th Jul 2014, 12:44 -
Device/software similar to Dazzle for Windows 8?
By JudgeGarth in forum Capturing and VCRReplies: 9Last Post: 19th Aug 2013, 19:44 -
Can't convert VOBs or MPEGs to MOVs properly
By Pianobum in forum Video ConversionReplies: 2Last Post: 21st Jul 2012, 22:03 -
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 17:22
