Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Hello.
    I done project in Sony Vegas 13.0.
    Time to render this. I use x264vfw with these settings:
    And after render I got video file, but one part of video done as simple black screen. What's wrong?
    These part (yellow hint):
    http://i.imgur.com/GJ8Eryj.png
    If I select only some part of project for render, but with "problematic part", like that:
    Then I got correct video file, I mean video of this part are correct.
  2. Today I try to render with default "MainConcept AVC/AAC" codec same problem. Even worse, because I got elongate black screen.
  3. Try enabling the VirtualDub hack. The AVI container wasn't meant to be used with out-of-order codecs. The VirtualDub hack is a way around that.
    If that doesn't work try disabling b-frames completely.
  4. Ok, I enable VirtualDub hack and add "--bframes 0" to "Extra command line" area. Do not help. Same black screen on same place.
  5. My bad (wrong settings apply). Looks like it's works! Thank you very much, jagabo.
