As the title says, I need help converting an MKV file to be playable on my DVD player. I used to use ConvertXtoDVD, but now that my DVDs have gone dry, I'll be using my USB flash drive. Can any of you guys suggest a good conversion program with very minimal quality loss? Also, what container should I convert in? Thanks!
Results 1 to 15 of 15
Please wait at least 2 days for bumping your post,people will help you as long as you are patient.
I would try avi divx/xvid. Use for example xmedia recode. Use the dvd player preset. Be sure to use max 720x576 pixels resolution / frame size.
Or get a cheap media player thay supports mkv. -
Most dvd players do NOT support HD resolutions. But you could try.
How do I know what codecs are supported by my DVD player? I can't seem to find them in the manual. It's a Samsung HT-Z210
Also, isn't there another way to get it to play without losing quality? It lost a lot of quality after conversion using the tool you recommended. -
Take a look at page 42 of your manual:
Samsung HTZ210 Manual Page 42
There are more details concerning bitrates and CODEC versions supported on that page.Supported Formats
WMV (.wmv) 720x480
DivX (.avi, .asf) 720x480They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
That means that the 1080p videos that I converted using ConvertXToDVD, burned to my DVD and played using the DVD player were only being outputed at 480p? I could've sworn it was 1080p! -
Looks like I've hit the end of the road.
"The system supports only the FAT file system and will not play a movie larger than 1 GB in USB mode."
Time to buy more DVDs. -
Hey, I'm not rich. If it ain't broke, don't fix it. Thanks for the help, anyway!
Converting Mkv to Xvid/Avi in order to play desktop DVD player
By zsbacsi in forum Video ConversionReplies: 1Last Post: 1st Jan 2014, 09:36 -
Converting mkv to vob-chinese dvd player
By cyrusash in forum Video ConversionReplies: 12Last Post: 3rd Mar 2013, 18:21 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Converting Bluray .mkv to play on BD-P1580 player
By Buu in forum Authoring (Blu-ray)Replies: 6Last Post: 18th May 2011, 10:28
