    Nov 2013
    Toronto
    Hello,
    I am re-streaming rtmp to rtmp without any problems using ffmpeg. But now I would like to re-stream rtmp to let's say 2 location at the same time.
    I know there is a way to do that with nginx.
    So in config file you can input push destination (rtmp) but how to do that if I need re-stream more than 1 stream.
    Original RTMP stream 1 --> output rtmp stream 1a -> output rtmp stream 1b
    Orignial RTMP stream 2 --> output rtmp stream 2a -> output rtmp stream 2b
    So in my case I have 2 inputs streams which need to be re-stream to 4 outputs streams (on 2 different servers)
    Any idea how to do that?
  2. I tried to use ffmpeg before to re-stream to 2 locations but I just found it really troublesome. Then I found restream.io. It helps me take one input stream to multiple output streams on multiple platforms. It's pretty neat.
    Nov 2013
    Toronto
    Thanks but they are limited to the most popular platforms. I need to re-stream to the platform which is not listed.
    Any other idea?
  4. to my understanding, you can stream to any custom platform, i.e. any platforms.Click image for larger version
Name:	Screen Shot 2016-04-20 at 16.14.12.png
