Hi, I'm trying to convert videos to PAL mpg2, 720x576, 16:9, mp2 audio.
No problem when the source are another MPG2, the result is correct, interlace is mantained.
But I'm trying to convert HD videos with interlace and the result MPG2 is progressive.
This is the command:
ffmpeg.exe -i TESTFILE.MP4 -vcodec mpeg2video -b:v 6000k -s 720x576 -r 50 -target pal-dvd -sws_flags full_chroma_int+full_chroma_inp -sws_dither none -threads 0 -flags +ilme+ildct -top 0 -bf 2 -trellis 2 -g 45 -acodec mp2 -acodec mp2 -ac 2 -ab 224k -ar 48000 -async 1 -y -f vob TESTFILE.mpg
I have tested with different -sws_flags, and without -sws_dither, -async, -f vob, -trellis, -bf, etc... and never retain the interlace.
This is the FFMPEG output:
ffmpeg version N-66917-g0e406ab Copyright (c) 2000-2014 the FFmpeg developers
built on Oct 16 2014 01:40:02 with gcc 4.9.1 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-lib
modplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrw
b --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinge
r --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --en
able-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-
libx265 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 54. 10.100 / 54. 10.100
libavcodec 56. 8.100 / 56. 8.100
libavformat 56. 9.100 / 56. 9.100
libavdevice 56. 1.100 / 56. 1.100
libavfilter 5. 1.106 / 5. 1.106
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'S:\test.MP4':
Metadata:
major_brand : mp42
minor_version : 0
compatible_brands: mp42mp41
creation_time : 2016-04-19 11:37:29
Duration: 00:01:43.81, start: 0.000000, bitrate: 29785 kb/s
Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv), 1920x
1080 [SAR 1:1 DAR 16:9], 29599 kb/s, 25 fps, 25 tbr, 25k tbn, 50 tbc (default)
Metadata:
handler_name : ?Mainconcept Video Media Handler
encoder : AVC Coding
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 18
9 kb/s (default)
Metadata:
handler_name : #Mainconcept MP4 Sound Media Handler
-async is forwarded to lavfi similarly to -af aresample=async=1:min_hard_comp=0.
100000:first_pts=0.
Output #0, vob, to 'A:\test.mpg':
Metadata:
major_brand : mp42
minor_version : 0
encoder : Lavf56.9.100
Stream #0:0(eng): Video: mpeg2video, yuv420p, 720x576 [SAR 64:45 DAR 16:9],
q=2-31, 6000 kb/s, 25 fps, 90k tbn, 25 tbc (default)
Metadata:
encoder : Lavc56.8.100 mpeg2video
Stream #0:1(eng): Audio: mp2, 48000 Hz, stereo, s16, 224 kb/s (default)
Metadata:
encoder : Lavc56.8.100 mp2
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> mpeg2video (native))
Stream #0:1 -> #0:1 (aac (native) -> mp2 (native))
Press [q] to stop, [?] for help
frame= 20 fps=0.0 q=0.0 size= 248kB time=00:00:00.78 bitrate=2598.0kbits/s
The source shows 50 tbc and the output is 25 tbc, but the same when the source are a PAL mpg2 and in that case the result is interlaced.
Any solution?
Results 1 to 15 of 15
If you meant actual interlaced content (not just encoding interlaced), you need to start with a 50p file, not 25p. 25 fps interlaced means 50 fields per second. 50 moments in time are represented per second. You are only starting with 25. If you had 50p to start with you can create interlace with -vf interlace or -vf tinterlace
Yes, the source is 50i, with interlaced noticeable in VideoLan (deactivaing deinterlacing).
The mpg2 result is 50i too (strict PAL), but VideoLan don't show the interlacing, like the source was progressive.
With -vf interlace (or tinterlace):
ffmpeg.exe -i S:\test.MP4 -vcodec mpeg2video -vf interlace -b:v 6000k -s 720x576 -r 25 -target pal-dvd -sws_flags full_chroma_int+full_chroma_inp -sws_dither none -threads 0 -flags +ilme+ildct -bf 2 -trellis 2 -g 50 -acodec mp2 -acodec mp2 -ac 2 -ab 224k -ar 48000 -async 1 -y -f vob "A:\test.mpg"
and then the result is like 12 fps instead 25, and without interlace. -
If source is "50i" , then you need to do an interlaced resize to SD . Typically you would bob deinterlace to 50p progressive, resize to SD 50p, then re-interlace. You cannot resize interlaced HD normally with progressive algorithm, otherwise you get nasty artifacts. From a 50p SD source, then either -vf interlace or tinterlace should work. Typically you would lowpass the results as well (otherwise you get line twittering), one of the ffmpeg filters has lowpass options , I forget which one right now, or you can do a vertical blur. It's listed in the documentation
I'll give you a generic template of a generic double rate deinterlace using yadif, progressive scale, SD color adjustment (you need to use colormatrix for Rec601 coming from an HD 709 source). The GOP size for PAL dvd is usually 12 BTW (50 is illegal), and alternate scan is usually used for interlaced encoding. Feel free to change the options or use -tinterlace instead or add the lowpass. This is reinterlaced as TFF .
This assumes your INPUT file is HD interlaced 50 fields/sec
Code:ffmpeg -i input.ext -vf yadif=1:tff,scale=720:576,colormatrix=bt709:bt601,interlace -pix_fmt yuv420p -vcodec mpeg2video -flags +ildct+ilme -alternate_scan 1 -trellis 2 -top 1 -dc 10 -g 12 -bf 2 -qmin 1 -qmax 31 -b:v 6000k -minrate 1000000 -maxrate 9000000 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -acodec mp2 -ac 2 -ab 224 -aspect 16:9 -f vob output.mpg
It's one step. ffmpeg can do it in a linear chain of filters. We're just breaking it down so you understand what is going on sequentially. See post above. Or -filter_complex if you have multiple branches or chains . You can set a batch file if you have multiple videos with the same target settings
But IMO, the ffmpeg MPEG2 encoder sucks, quality wise. Very poor. Some people have tweaked the settings, using custom matrices...but still not very good -
poisondeathray, now works fine with the HD source, but... with the mpg2 PAL source the result has the fields inverted.
But I'm going to try changing parameters, thanks a lot. -
-vf yadif=mode=1:parity=-1:deint=0,scale=720:576:sws_flags=lanczos+accurate_rnd+full_chroma_int+full_chroma_inp:sws_dither=a_dither,tinterlace=mode=interleave_top
Hi, with BFF works fine with mpg2 sources, but not with HD. I have removed the ":tff" in the -vf and now works fine with both sources.
Thanks to all. -
ahh I see, you meant wrong field order when deinterlacing the SOURCE. That will give jerky forward/back/foward/back playback. By convention, HD is TFF (99.9% of HD interlaced is TFF) . But be careful, because SD can be EITHER TFF or BFF. I "hardcoded" the TFF value in the example, because you initially inquired about HD interlaced.
error source url ffmpeg.help me
By quynhchellam in forum Video Streaming DownloadingReplies: 3Last Post: 20th Jun 2014, 10:49 -
FFMPEG writing metadata from another source
By marcorocchini in forum Newbie / General discussionsReplies: 24Last Post: 20th Apr 2014, 13:41 -
Long lost Return of the Jedi outtake footage found - laserdisc source
By yoda313 in forum Off topicReplies: 2Last Post: 5th Nov 2013, 03:59 -
Tell ffmpeg to use (almost) the same (audio) quality as original source?
By pxstein in forum Newbie / General discussionsReplies: 8Last Post: 16th Oct 2013, 14:39 -
FFmpeg Runtime error / FFmpeg git-df82454 32-bit Static (2012-10-03)
By MashedPotatoes in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2012, 18:22
), change these : interlace=scan=bff and -top 0
