I have a MacGyver Font that is in gif format , is there a piece of freeware that can directly convert gif,jpg, ect to font so I can put them in the ttf file?
so I can use them in Aegisub, John
Apps like that may do varying levels of OCR (optical character recognition) that converts to plain text, but none do vectorizing/tracing & streamlining & glyph transformation, which is what is necessary to do what the OP wants. A combination of Illustrator/Freehand/Streamline & Fontographer will do it, but only if you have lots of skill & patience.
Scott -
Ok, so that changes it from a 2 or 3 app workflow to a 1app+ plugin workflow, but the steps are the same, and the "tweak" portion is the part which trips up those who aren't skilled in fonts. Without painstaking tweaking, you end up with a very uneven set of glyph shapes, weights and spacing. It is as hard as all that (I say, having done it a few dozen times before, myself).
It is nice to see there are font generation alternatives, though.
Scott -
I get an error message when I do that. Something like its a invalid font file. How do you load a gif in fontforge? Does it have to be grayscale? John
Change Fonts in Subtitles and Title in mkv File
By RBCC in forum SubtitleReplies: 26Last Post: 19th Apr 2017, 14:25 -
Program to edit subtitles whilst maintaining existing fonts and positions
By Acorn444 in forum SubtitleReplies: 6Last Post: 18th Mar 2015, 17:50 -
How to display fonts with subtitles in MP4 container?
By Jamaika in forum Software PlayingReplies: 2Last Post: 18th Feb 2015, 09:58 -
Blu-Ray player that reads MKV files with options for subtitles sizes/fonts?
By JukeboxAMI in forum DVD & Blu-ray PlayersReplies: 4Last Post: 31st Jan 2015, 15:02 -
Editing Subtitles with Fonts
By YellowDog in forum SubtitleReplies: 3Last Post: 18th Aug 2014, 11:34
