I haven't worked with video for 4 years, so please bear with me...
I captured a bunch of video on a camcorder I'd never used before, and now that I've transferred it all onto my MacBook Pro I see that it's all .AVI which I cannot play in Quicktime or edit in Final Cut Pro / Premiere Pro / iMovie. Quicktime suggested I download some component which promised to make it work- no dice. I downloaded MPEG Streamclip, but when I try and drag my AVI files into it there is just a blank white screen with no audio. When I select "Export to MPEG" it creates a 'video' file that is just another totally blank screen (black this time) with no sound.
I have no clue where to go from here... in the past MPEG Streamclip always saved me, and that is all I'm seeing in the help forums online but I don't know what could be going wrong... any advice would be MUCH MUCH appreciated, I've been trying for days here to no avail. If it helps at all, I am using MBP OS XEl Capitan.
Please + Thank You
You could try convert/remux the avi with ffmpeg (or a frontend/gui like iffmpeg) to mov or some format that final cut pro like.
If that fails then:
Can you play the avi videos with VLC media player?
Post the details from the avi. Use mediainfo, open avi, view->text and copy everything.
How to convert any video to Prores/Premiere/iMovie/Final Cut Pro format
By Baldrick in forum User guidesReplies: 1Last Post: 23rd Feb 2016, 19:07 -
Imovie, final cut pro, adobe premiere pro questions
By parker7d7 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2015, 03:46 -
Final Cut Pro X vs Adobe Premiere Pro CS6 for capturing/digitising DV
By danvideodiary in forum Capturing and VCRReplies: 11Last Post: 7th May 2014, 19:28 -
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 19:59 -
Issues Editing Skype's .MOV's in Final Cut Pro.
By macphoto in forum EditingReplies: 1Last Post: 14th Sep 2011, 21:18
