Anybody can help me about how to remove grains from video, and make clean frames ?
With a denoiser. AviSynth, Virtual Dub, and many NLEs have them available in varying degrees of quality.
I don't know. The word 'denoiser' is pretty self-explanatory. They remove noise, film grain, sometimes small amounts of dirt and other crud in your film. I use AviSynth and here's a page on some (only some) of the denoisers available if you use AviSynth:
http://avisynth.nl/index.php/External_filters#Denoisers
Maybe if you provided a short ten-seconds from your source (DVD?) you will receive more informed advice on how to treat it.
And if you do a Google search on 'denoiser' you'll find much more information about them, for both audio and video. -
manono also mentioned VirtualDub, and that might be a good place to start. A bit simpler to use, though not as efficient as AVISynth.
Some VD filters here: http://www.infognition.com/VirtualDubFilters/
How would I remove grains from a video ?
By PrinceSwaraj in forum Video ConversionReplies: 7Last Post: 27th Feb 2015, 22:59 -
Capturing with the ability to instantly remove clip?
By drakedog in forum Capturing and VCRReplies: 0Last Post: 16th Jun 2014, 20:06 -
How can I create a 2 sec solid black video clip without a video camera?
By haggis999 in forum Newbie / General discussionsReplies: 47Last Post: 21st Mar 2014, 10:03 -
Remove extra noise from music video clip
By akakiami in forum Video Streaming DownloadingReplies: 2Last Post: 7th Jun 2013, 13:52 -
I am looking for a way to remove background noise from the clip
By Keeran in forum AudioReplies: 32Last Post: 16th Apr 2013, 12:55
