For the past week ive been trying to fix my video gameplay that has been captured by shadowplay since all the videos (around 200 files = 2TB) is missed up when I add them to Adobe Prmiere Pro because nvidia refuse to use constant frame rate but instead they wont use Constant frame rate
So heres I will tell you how to change mp4 Variable Frame Rate VBR to Constant Frame Rate CFR without re-encoding in a very simple way without even loosing quality
I tested it on my videos that has been captured by Shadowplay so dont blame me if it doesnt work for you
Just to be sure I have GTX 980 Ti and the settings I used in shadowplay 60FPs to 130Kbs
First you need Avidemux you can get it here
http://fixounet.free.fr/avidemux/download.html
Second 15 Min of your time
Guide:
1- Install Avidemux on you computer Windows or Mac (Mine is Windows 10 x64)
2- Add the video you want in Avidemux
3- On the left side Video Output (Copy) - Audio Output (Copy) - Output Format (Mpeg TS Muxer (ff))
4- In Output Format (Mpeg TS Muxer (ff)) click Configure and untick VBR Muxing and change the Mux rate (MBits/s) = 60
5- All the other settings is by default I didnt change any other thing
6- Click save it will be saved as .ts file
7- Wait till it finish it might take time depends on your video
8- Add the video on your Adobe Premiere project and see
9- If its works share this post so every one whos suffering like me can use this guide
Heres a test of one of the videos
NOTE: VIDEOS CONVERTED TO ts HAS DOUBLE THE SIZE SO MAKE SURE YOU HAVE SPACE
THANK YOU VERY MUCH PAL! I've been trying to find a solution that doesn't take 3 times the length of every video to move from VBR to CBR. Your solution worked perfectly, you saved my life of editing shadowplay videos!
ShadowPlay & YouTube
By BadContrakt in forum Video ConversionReplies: 2Last Post: 12th Jan 2016, 07:37 -
Multiple problems with Shadowplay and Virtualdub (64-bit)
By Sardaukar in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2014, 14:27 -
Final Cut Pro X vs Adobe Premiere Pro CS6 for capturing/digitising DV
By danvideodiary in forum Capturing and VCRReplies: 11Last Post: 7th May 2014, 18:28 -
Nvidia Shadowplay 4:3 Recording Stretched to 16:9 - How to fix?
By Keil in forum Video ConversionReplies: 0Last Post: 5th Nov 2013, 10:52 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43
