Hi guys,
Firstly I am a n00b in video editing, got videos 600mb sections of "dashcam"- driving recorder.
They are in 5 minute formats, but I need two sections of each (10- 30s) and ideally,
I need to not to have Audio on couple of them.
Tried to use few, but lost as in errors or getting just sound or else (DVDFab, FreeVideoCutter, FreePM4Cutter)
Could somebody reccomend simple, basic tool, to do so?
BTW its Win 7 x86, Intel i30 Video card- fairly old laptop, with 2gb RAM
Many thanks!
	Also, it would be good to hide number plates of few cars if possible, but in motion, they are moving about the screen, also size keep on changes...
	Your second post has complicated your request by orders of magnitude.
 The first request can be handled by a simple avisynth script using QTInput (a separate download) for loading.
 You may want to look into a low-cost but excellent NLE like Sony Movie Studio.
 Before this weekendd I would have suggested quicktime Pro, but Movie Studio is only about $10 more anyway.
 A free alternative is Aviutl, but it works differently than most standard NLEs.
	Tried AvideMux- didnt work :/
 Thanks for advice!
 Perhaps reg plates not that biggy of an deal and purchassi.. purcha...byuiin...DL! is the way I see them, so Sony and etc, apart from being heck too complicated, I'll pass
 DL'ing, trying AviUtl ExtraPack
	huh, although seemed as good interface- I got utterly lost with AviUtil
 Trimmed nicely (simply) using Formatoez Format Factory (although freeware is packed full with bugs), but those clips audio remains...
 Is it possible to do so with some simple tool please?
	You may be able to do some simple appending with something like AviDemux, but getting rid of the audio selectively will be tricky. Depending on the codec and structure of your mov it may or may not load at all.
 I recommended Movie Studio before because it really is one of the simpler tools for what you want to do. You don't have to know the ins and outs of every function for your project. There's a free trial.
  [Q] Cutting/Splitting Raw .Mov Files From Canon 60DBy phaze3131 in forum EditingReplies: 6Last Post: 27th Nov 2014, 15:27
  I need a tool for cutting MPEG2 in an MKVBy ndjamena in forum EditingReplies: 3Last Post: 19th Sep 2014, 07:49
  Incredibly Simple - Yet Not. Basic Cutting.By modene1 in forum MacReplies: 10Last Post: 23rd Aug 2014, 11:21
  Tool to pull apart MOV with AVC/AAC inside?By DRP in forum Video ConversionReplies: 3Last Post: 20th Aug 2012, 23:45
  MOV: Editing: Joining/Cutting/Splitting softwareBy taboo in forum EditingReplies: 5Last Post: 8th Aug 2011, 19:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
