I recently encoded and muxed a bunch of A/V files into MKV with MKVMerge, and found one with a damaged GOP. I'm not entirely convinced that it's MKVMerge's fault, as it could be a few other things. To try to stave off data corruption I do use Teracopy to copy my files, and use the CRC error checking function always.
Just wondering what MKVMerge uses to check to make sure the video and audio is copied without errors, if MKVMerge even has such abilities. I've searched Google without really finding anything besides this Doom9 thread:http://forum.doom9.org/archive/index.php/t-164388.html
Seems like the only method would be to mux into MKV, and then demux the files out just to CRC/SHA check them, which would take forever with many files.
How do you check for damages gops? So I can test and see if have any problems with my mkvmerged mkvs.
I found it by chance the old fashion way, simply by watching them myself. Every so often a video I'm playing will have a decoding problem, caused by the HDD not providing the video in time or the CPU is overloaded. But this particular GOP error persisted when attempting to play in different players, on repeated attempts, defragmenting the file (which it did not really need), and even at reduced playback speed.
If someone has a better/faster way of finding errors I'd certainly like to know. -
Can you provide a short clip with the damaged GOP so I can see it? I haven' seen something like that.
Are you absolutely certain it wasn't a decoding problem when the source was being re-encoded?
Not that I find problems with encodes much.... almost never.... but if I do see something that looks like a glitch or blocking or what seems to be frames that aren't being decoded properly etc, it's invariably a problem with the source. -
mkvmerge gui is corrupting my mkv files when muxing
By steve1232 in forum Newbie / General discussionsReplies: 51Last Post: 25th Feb 2022, 12:46 -
MKVmerge GUI help!!
By Skylark in forum Video ConversionReplies: 22Last Post: 11th Nov 2015, 02:04 -
using mkvmerge gui
By zoloabc in forum EditingReplies: 8Last Post: 26th Jun 2014, 13:44 -
Muxing with mkvmerge
By sharu006 in forum Video ConversionReplies: 7Last Post: 14th Dec 2012, 12:48 -
Batch subtitle muxing - mkvmerge
By mkr10001 in forum EditingReplies: 1Last Post: 18th Feb 2012, 13:03
