Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Aug 2015
    I have Magix Movie Edit Pro 2016 and have tried burning a Blu-Ray and I'm not having much luck. Using prior editions of Movie Edit Pro, I didn't have issues with burning DVDs so I thought Blu-Ray discs wouldn't be all that different. Especially since I know just enough to get by
    The last time I tried burning a disc, Movie Edit Pro 2016 says the burn was successful. But when I put it in my Sony BDP-3500, nothing happens. It recognizes the disc as a BD-R BDMV and that's it. I've read that Imgburn is a good program for burning discs. So I pulled up the folders that Movie Edit Pro 2016 created and tried to put them on a BD-R. Same result which is to say nothing happened.
    I put in a blank BD-R in the player just to make sure and it recognized that as being unformatted. So when it shows BD-R BDMV it's at least recognizing something has happened to the disc.
    I have more than one computer so I went with an external burner. In this case a Samsung SE-506CB/RSBD.
    So it doesn't work when I try burning with Magix Edit Pro 2016 or with ImgBurn. I have notice ImgBurn has a million different settings that can be changed. Should any be changed or leave them all alone? This is not an MKV file. Only reason I mention that I saw some threads where others had some issues with MKV files and blu-rays. Not the case here.
    I had it set for an MPEG-2 file in Movie Edit Pro 2016. Should I have gone with H.264? Or does that even matter?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You can't just "burn something to a disc-shaped object" and expect it to end up as a working, DVD or Blu Ray disc. There is prep work involved(by software) for DVD and much prep work involved for Blu Ray.
    I guess magix made a compliant blu-ray bdmv folder? See example: https://www.videohelp.com/hd#filestruct
    And you burned the bdmv folder correctly? Imgburn should say that you have a blu-ray/avchd when you are adding the BDMV folder. See http://www.dvd-guides.com/guides/blu-ray-copy/260-burn-blu-ray-avchd-using-imgburn
    But I would also try h264. Even though mpeg2 is blu-ray compliant.
    You could also try burn it on a DVD-R.
    Or your sony might not support homeburned blu-ray bdrs/dvdrs.
    Aug 2015
    What?!?! You mean I can't burn Blu-Ray movies onto Frisbees?!?! I had no idea!!! I figured any disc shaped object would work and so Frisbees are disc shaped and so I thought I'd burn Blu-Ray movies onto them which would make it multi-purpose: fun at the beach and then later watching movies on that same "disc-shaped object."
    This completely changes everything!!! I don't know what I'm going to do now.
    Aug 2015
    First off, thank you for actually trying to help me as opposed to being condescending.
    According to Amazon's website, my Sony does support BD-R and BD-R DL, among other formats.
    I checked the folder that Magix created and compared it with the link you provided and I had 4 out of the 5 folders with matching files. The exception was AUXDATA. My AUXDATA folder is completely empty.
    I haven't tried to burn in h.264 yet.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Well until the next post replying to Baldrick, you never mentioned any kind of folders that resulted from authoring a disc via Magix. Without the key words "authoring" or "folders"....it's easy to make the assumption that you MAY just be burning video files to a disc (as data).
    On the plus side...now you know why I never got into "Blu Ray".....too much like work. Too many variables involved even after a reputable program gives you apparently viable "folders".
    I'll stick to DVD if I NEED to burn something.
