Hey guys,
I have recently obtained a DataVideo MP6000, which I am planning to use as a TBC for converting old VHS tapes.
I currently use a JVC HR-S7860 to play my old vhs tapes, so when I integrate the TBC into my setup, should I turn OFF the TBC and other video correction settings that are on at the moment on the JVC?
I admit I'm relatively new to VHS restoration, I purchased the Datavideo at a very low price. From research I know they are professional level pieces of equipment. Could anyone provide any information exactly on how good it actually is? (I dont really have a gauge :S)
Heres the Spec:
IEEE1394 Fire Wire DV25 In & Out (NTSC 4:1:1 - PAL 4:2:0: - DV25 Format)
S-Video( Y/C) (DIN 4-Pin, 75ohm), Y:1.0Vp-p, C:0.627Mvp-p
Composite Video: 75ohm 1.0 Vp-p
Component Y:U:V
Black-Burst/Gen-lock out
Bandwidth: 5.0MHz
Noise ratio: 50 dB
4:2:2 Time Base Corrector
Digital and Analogue
Video Correction
Brightness :+/-30%
Contrast :+3/-6 dB
Saturation:+6/-10 dB
Hue :+/-20 (NTSC Only)
Audio In & Out
Balanced (XLR)
Un-Balanced (RCA)
DV Sampling : 12-Bit 32KHz or 16Bit 48KHz
Bandwidth : 20-20KHz
S/N Noise ratio : 65 dB
Distortion rate : 0.1%
Enable both.
Read this: What is a TBC? Time Base Correction for VideotapesWant my help? Ask here! (not via PM!)
Is a full frame TBC necessary or VCR's builtin TBC enough?
By DNICE_ONE in forum Capturing and VCRReplies: 37Last Post: 22nd Dec 2018, 15:03 -
VHS conversion: dedicated converter or PC?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2014, 17:38 -
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 19:31 -
Gone through several still cameras: Do I need a dedicated camcorder?
By Dave2ic in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Jun 2013, 22:25 -
Dedicated Video conversion PC
By tonyaldr in forum Video ConversionReplies: 14Last Post: 14th Aug 2011, 23:08
