Here's the MediaInfo of the original video.
General
Complete name : C:\Users\Bruce\Desktop\test.mkv
Format : Matroska
Format version : Version 2
File size : 1.99 MiB
Duration : 2s 95ms
Overall bit rate : 7 949 Kbps
Writing application : libmatroska 1.4.1
Writing library : SolveigMM Matroska Muxer Version 1.0.1502.18
Video
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2s 85ms
Width : 1 904 pixels
Height : 1 072 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 2s 95ms
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : 10ms
Language : English
Default : No
Forced : No
Here are the instructions I gave HandBrake.
Container mp4, not web optimized, no change to the resolution, anamorphic loose, modulus 2, cropping automatic, detelecine off, deinterlace off, denoise off, deblock off, grayscale off, video codec H.264 (x264), fps same as source and constant, quality constant at 0, x264 preset ultrafast, x264 tune none, fast decode off, h.264 profile high, h.264 level 5.1, no extra options, audio source 1 English (AAC) (2.0 ch), codec AAC (avcodec), bitrate blank, mixdown none.
Here's the MediaInfo of the resultant video.
General
Complete name : C:\Users\Bruce\Desktop\test.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/iso2/avc1/mp41)
File size : 33.3 MiB
Duration : 2s 86ms
Overall bit rate : 134 Mbps
Encoded date : UTC 2016-04-17 21:24:18
Tagged date : UTC 2016-04-17 21:24:18
Writing application : HandBrake 0.10.5 2016021100
Video
Format : AVC
Format profile : Baseline@L5.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 2s 86ms
Bit rate : 134 Mbps
Frame rate mode : Variable
Frame rate : 23.976 (24000/1001) fps
Minimum frame rate : 23.974 fps
Maximum frame rate : 23.981 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 2.734
Stream size : 33.3 MiB (100%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0:0 / me=dia / subme=0 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=240 / keyint_min=24 / scenecut=0 / intra_refresh=0 / rc_lookahead=0 / rc=crf / mbtree=0 / crf=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=240000 / vbv_bufsize=240000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=0
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2s 48ms
Bit rate mode : Variable
Bit rate : 167 Kbps
Stream size : 41.7 KiB (0%)
Title : Stereo / Stereo
Language : English
Default : Yes
Alternate group : 1
Could someone please explain this to me?
Set it for constant frame rate, and then pick the correct frame rate in the above click box(change from "same as source").
Handbrake encoding at Variable FPS when Constant is chosen
By ManiKz in forum Newbie / General discussionsReplies: 7Last Post: 10th Dec 2019, 15:16 -
Should I use Constant Frame Rate encoding?
By Downgraded286 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Mar 2016, 01:37 -
Handbrake Newb: Same as Source + Variable Frame Rate
By EmptyMorale in forum Video ConversionReplies: 5Last Post: 30th Dec 2015, 09:38 -
How to find out frame exposure time in a variable frame rate .mov file...
By bananas100 in forum EditingReplies: 5Last Post: 24th Oct 2014, 19:18 -
Where is Constant Quality Rate in Handbrake?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2014, 21:39
