hi i have venturer double screen dvd player for wich is about ten years old and have lost the 2 din cables that go from screens to the head unit.i have tryed to get hold of replacement leads but apperntly they are now obselete.is there any other cables i could get that would do the same job.thank you
you would need to know the pin out of the cable connections, and you may be able to make your own.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
Wingnut2003 is right. There's no standard for the pinouts on a 9-pin DIN. You'll have to get a cable from the manufacturer or build your own based on pinout information for the particular device.
One of the better resources for connectors pinouts is: http://pinouts.ru/
But for specific devices, searching for the player name and manufacturer is probably the best. Good luck.
Also be aware that the location of the 9 pins may vary. So if you make your own cable you'll need to get the right connector.
im not clever enough to make my own cable lol.wish i could buy one somewere
Look for the same player (with cables) on ebay. Sometimes people sell "non-working for parts" items cheaply.
Looking to buy a Y/C 358 (JVC 358) 7-pin to 4-pin s-video cable
By houstonian73 in forum Off topicReplies: 10Last Post: 12th May 2015, 16:35 -
How do you store your audio/video cables? And computer cables as well?
By yoda313 in forum Newbie / General discussionsReplies: 12Last Post: 29th May 2012, 14:19 -
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 01:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 21:03 -
female BNC -> 6pin Mini DIN
By nkordyjaka in forum Capturing and VCRReplies: 5Last Post: 27th Apr 2011, 09:56
