Hi all, just wondering what's the best way to edit MKVs I have on my NAS? for example I'd like to add forced sub titles or remove all other audio tracks besides English off my MKV's and the only way I know of doing that is to use a editing software that's installed on my laptop to access the file on my NAS which seems to take forever.
PS What's the best software for editing MKV's especially one that can make it easier to edit files on my NAS. Thank you!
Open Windows Explorer with that particular NAS directory. If windows for some reason would not see particular NAS under "network", it happens a lot to me, type into Windows Explorer something like:
\\name_of_your_NAS_here
and drag&drop that file onto mkvmerge GUI, add force subtitles there, uncheck tracks you do not want to and save it again on that NAS. Delete that original MKV after no errors would be generated and new MKV would be alright. Report back if you can, if it works or not, because googling this problem would direct folks back here.
Particular permission has to be set on that NAS, so you are able to write a file on it, not just read it, defaults might be set for just reading, not writing , you have to have those directories set as shared in the first place etc.Last edited by _Al_; 25th Apr 2016 at 20:40.
not likely. the nas uses a small version of linux and with a terribly slow processor/little ram it would take ages to do anything. your laptop has to have a faster cpu. if your network is the bottleneck move up to gig routers and cat6e cable.
Hmm okay, thanks again but I feel like I've tried this already, with the method you're suggesting aren't I just reading the file off the NAS using a copy of the program on my laptop and writing back on to the NAS over the network?
If so, it usually takes a long time as it has to read the MKV off my NAS, do it's thing and write it back. -
Then look into ffmpeg if it works on your NAS itself, ffmpeg can work with MKV and its streams thru mapping. Or directly mkvtoolnix might run on NAS as well. You have to find out if that is possible on your NAS. That might involve some geek stuff, executing commands. If someone already compiled something or published how to make it work for your NAS, you might be half way there.
Trying to edit .mkv with Avidemux..
By brawltimore in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2013, 10:04 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
MKV info edit help
By vidyarathne in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2012, 13:24 -
efficient MKV conversion
By harsh117711 in forum Video ConversionReplies: 2Last Post: 15th Mar 2012, 10:08 -
How to edit MKV Tags? Is there any MKV Tag Editor available?
By Bonie81 in forum Video ConversionReplies: 1Last Post: 6th Nov 2011, 12:20
