  1. I can see it in this screenshot no my screenshot.
    But I can't figure out what filter and where to download and how to add it to the graphedit.
    In this link the top image https://forum.videohelp.com/threads/371206-Help!-GraphStudio-recording-stopping-randoml...on-stop-button
    Or the image:Click image for larger version
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Should be under Video Compressors after you install the package.
    There's also GraphStudioNext, by the way. Handy search box.
Name:	GraphStudioNext x264vfw.PNG
  3. vaporeon800 Hi,
    Can you tell me what package to install and where to get the package from ? Maybe just the package name is enough.
    Thank you.
  4. I downloaded the package from here if it's the right package: http://www.free-codecs.com/x264_vfw_download.htm
    Installed it.
    Then running the grapheditplus but I can't find it any where there. I tried under directshow filters and also tried marked all categories but it's not there.
    Then tried to click in grapheditplus on the Add button and went to the directory where the package installed: C:\Program Files (x86)\x264vfw
    But in this directory I have only two .ico (icons) files and one uninstall exe file.
    What am I missing ?
  5. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    As I said, Video Compressors. Not DirectShow Filters.
    GraphStudioNext can group everything together under ALL, while judging from the screenshots, GraphEditPlus can't.
  6. vaporeon800 i don't have it on the graphstudionext i guess since i didn't install the package yet of the x264vfw H.264/MPEG4 AVC codec
    can you send me the graphstudionext with the filters you have already ? the one in the screenshot you added.
    I can't find a link for download the package.
    I tried the graphstudionext and it's not there. Looked under Video Compressors. I have only 9 filters under Video Compressors and it's not there.
    From the link you posted i download this version:
    Download GraphStudio Next 0.7.0.430 64-bit
    I select graph > insert filter
    And when running it under Video Compressors i see:
  7. Make sure you're not trying to mix 32 bit and 64 bit. Try 32 bit GraphStudioNext.
  8. sneaker is right. The 32 bit is working. I tried the 64. Thanks you all.
