    Apr 2016
    Denmark
    Hi.
    I have 3 VHS tapes with a total time of 9 hours that i would like to put on a DVD disc.
    My setup is:
    Sanyo VHR-778EV VHS player -> Phono cables -> Sony DCR-TRV330E -> FireWire -> MacBook Pro Retina 2013 -> iMovie 9.0
    Since it is imported in .dv format each VHS tape is about 38GB when importet as .dv Even though i export it to iDVD, it will only allow 120 minutes.
    Is it possible to convert the video in to some other format so i have have all 9 hours on one DVD, maybe a dual layer DVD?
    The picture quality of the VHS tapes are really pore, see attached photos.
Name:	Skærmbillede 2016-04-15 kl. 22.14.44.png
Name:	Skærmbillede 2016-04-15 kl. 22.14.23.png
Name:	Skærmbillede 2016-04-15 kl. 22.13.54.png
    Mar 2008
    It can be done, but the video bitrate will drop pretty low, but there are a few things to do that will help.
    For example, use a low bitrate for the audio, give extra bits to the video
    Use 1/2 D1, 352*720 (PAL)
    Use a matrix designed for lower bitrate
  3. Filesize = duration * bitrate.
    In order to get 9 hours on a single DVD playable on a standalone DVD player your video is going to be in the 500-1000 kb/s range. While technically possible, it 's not really something you'd want to watch.
    Poor quality videos are more difficult to compress efficiently than good quality videos.
  4. Member Cornucopia's Avatar
    Even 1/2 D1 would look poor at 1.85Mbps or less (assuming you used ~128kbps AC3, and used DVD-DL discs, giving you 9+hours). Put it on 2 DL discs (or 3 SL discs) and you should have enough room for decent quality encodes (well, given the poor quality of the source, don't expect too much).
  5. Member DB83's Avatar
    Jul 2007
    You could even go down to VCD quality(352*288) if your authoring program supports it.
    But why insist on putting all this footage on one disk ? Blanks, even good quality ones, are really cheap these days so really just one 3-hour per disk.
  6. Member Cornucopia's Avatar
    I don't recommend that, as you will lose motion smoothness and actual vertical resolution (480i60->240p30). One of the few things VHS still had going for it.
    I agree with DB83, though: discs are cheap enough.
    Since your tapes came as 3 segments, why not KEEP them as 3 segments, then you'll know where the footage came from for a particular disc.
