    Aug 2015
    Quebec, Canada
    Hello
    I'm trying to convert some DVD to .MKV files using TMPGENC VMW5.
    Source is widescreen (16:9, 1:78:1) which is full screen.
    I'm encoding using aspect 16:9, 720x480. BUT each time, I'm getting little tiny black bar at the top/bottom of the screen. I tried Handbrake with the same setting without any problem and I'm getting a real full screen picture.
    Anyone knows how to make a perfect rip with TMPGENC VMW5 ?
    Thanks everyone
    kalemvar1
    Can't you crop the video in tmpgenc? Search the manual/help.
    Handbrake is probably using the auto crop feature.
    Or use MakeMKV if you don't need to shrink the dvd.
    Aug 2015
    Quebec, Canada
    Thanks baldrick for your help.
    I can't crop them because the original source is full screen (and exactly what it's suppose to be), those little tiny bars at the top/bottom appear only during the making of the MKV file. (also if this can help, when I watch the .mkv using VCL they only appear when I'm full screen)
    any idea ?
  4. 1) Are you certain your original source isn't a 1.85:1 movie? That would produce the results you describe.
    2) In the TMPGenc resize filter choose: Full Screen (No Margin) and uncheck the keep aspect ratio box.
    If you get the same results, see 1).
    Aug 2015
    Quebec, Canada
    I'm getting the same result.
    when I play the dvd on the TV, the screen is full, 1:78.
    here is the Clip Properties.
    Interlace/Top Field First
    Aspect Ratio: Pixel 40:33 (NTSC 16:9)
    Filter / Resize
    Full Screen (No Margin) and keep aspect ratio unchecked
    Setting for the MKV
    Stream Video: MPEG-4 AVC
    Video Encoder: x264
    Profile Level High 4.1
    Aspect Ratio: Displey 16:9
    Frame rate 29,97 ftp
    Displey Mode: Interlace
    Maybe that can help
  6. Originally Posted by kalemvar1 View Post
    That could be easily explained by the television's overscan. How about a sample cut from the DVD and not reencoded? 10 seconds will be plenty.
    You can use DGIndex, among other programs. Use the [ and ] buttons to isolate a small piece and then File->Save Project and Demux Video. Upload the resulting M2V file.
    Aug 2015
    Quebec, Canada
    Ok, I've run lot of test this after noon and I've located the problem but not fixed it. When I select the aspect ratio aspect of the .mkv it should be at 720x480.
    At 720x480 = I've those tiny bars top/bottom.
    At 716x480 = The Picture is correct no bar
    At 720x478 = The Picture is correct no bar
    I've tried this with 1:78 and 1:33 dvds. Always the same problem.
    Any solutions ?
    As always, Thanks for your help gentlemen
