I tried using both Solveig Video Splitter and ffmpeg to create a gif from a video with the following details,
General
Complete name : C:\Users\Bruce\Desktop\test.mkv
Format : Matroska
Format version : Version 2
File size : 404 KiB
Duration : 1s 320ms
Overall bit rate : 2 506 Kbps
Writing application : libmatroska 1.4.1
Writing library : SolveigMM Matroska Muxer Version 1.0.1502.18
Video
Format : AVC
Format profile : High@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 12 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1s 320ms
Bit rate : 2 072 Kbps
Width : 720 pixels
Height : 572 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.201
Stream size : 334 KiB (83%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
A woman's lipstick, red in the video, turned browny orangey yellowy in the gif. What should I do? Bear in mind you'll have to give me step-by-step instructions as I understand ZERO about videos.
Results 1 to 17 of 17
The problem is that the GIF can only use 256 different colors. Other shades are simulated with error diffusion, dithering, etc. If there's very little red in the video, and a lot of other colors, a palette optimized GIF may not include red shades in its palette. That will result in the type of shift you're seeing. You need to modify the palette to include the reds you need for the lips. You could do that by modifying the palette directly, or by somehow increasing the amount of red lips in the video. For example, when building the palette crop the image down so that the lips take up proportionally more of the frame(s). Or crop and enlarge the lips then overlay the enlargement over an otherwise redundant (color wise) portion of the frame. Once you have a more appropriate palette you can generate the finale GIF with that palette.
Another thing you might try is increasing the saturation during the palette building phase. That will give you more intense colors to work with in the GIF.
Basically, GIF isn't intended for full motion, full color, video. -
Thanks for the advice. I really wouldn't like to interfere with the video in any way. I was just hoping there might be an easy and quick method of just correcting the colour imbalance. From now on, if colour is really important, I'll just convert to an APNG instead. Thanks again.
APNG is abetter choice than animated GIF. Unfortunately, support isn't as wide.
This is not color shift but wrong color quantization/reduction selection. In GIF you are no longer due color shift but you must from all colors in your picture select best 256 at max - later you must apply one of those 256 colors to picture.
In your case better color reduction algorithm may work better - IMHO best you can do is select key frames in one large picture (creating new picture that is mosaic of your key frames) and use very good color quantization algorithm to generate palette file and later apply this palette file to your video.
Be careful with APNG as it may be not supported by players/browsers - GIF is de facto standard for animation but APNG not. -
? Well for GIF you MUST reduce number of colors as GIF is format for 2 - 256 colors pictures - you may use better algorithm for color reduction (neuquant should be OK http://members.ozemail.com.au/~dekker/NEUQUANT.HTML http://pngnq.sourceforge.net/ )
Instead APNG/GIF use WebM and regular video (unless you must have hard edges and reduced color palette but from your description is not a case) -
No, I definitely don't want those. I'd just like whichever animation format I use to look as close to the original video as possible. Thanks for the links to those algorithms but I'm afraid I don't have a clue as to how to go about using them.
APNG uses WebMs? That's weird. I just tried making a WebM video and loading it into VirtualDub APNG Mod and it didn't work. Unsupported format message. -
Video is not drawing, for video compression you need to use proper compression, gif compression is not for video but for limited color (up to 256) usually drawing.
Are you able provide details why you must use gif (apng) not video compression?
Using neuquant is very simple - search for picture with those lips - export it to 24 bit picture, apply neuquant, 256 color version of picture will be created, export this picture as palette, use palette to create gif. -
No reason. I'm perfectly fine using HTML5 instead of gif. Just wondering if there was a really easy way to fix the gif.
Isn't that what ffmpeg does though? And when you say apply NeuQuant, OK, but, how? How do I "apply" NeuQuant. You've got to understand, I understand nothing. I have no idea what I'm doing. I need step-by-step instructions.Using neuquant is very simple - search for picture with those lips - export it to 24 bit picture, apply neuquant, 256 color version of picture will be created, export this picture as palette, use palette to create gif. -
[QUOTE=Bruce Wayne;2441222]
No easy fix - format limitations - 256 colors are shared between all video frames.
http://www.imagemagick.org/Usage/video/
Simply color re-quantization algorithm ignored red lips and red was substituted by other closest color
yes - this is performed by ffmpeg but not trough neuquant color requantization but other algorithm - gif capabilities in ffmpeg are somehow reduced and imagemagick offer substantially more tools to perform video 2 gif but still not support some of modern color requantization algorithms like neuquant or scolorq ( http://bisqwit.iki.fi/jutut/colorquant/ ) .
Your problem with gif laid in generating optimum 256 colors for frame - sometimes manual color selection seem to be only one option.
Color reduction is very tricky problem http://www.imagemagick.org/Usage/quantize/
If you can use video (HTML5) then not use gif for video like source - gif may work for video without many colors (cartoon, drawings etc) .
Also video size will be smaller and at the same usually better looking.
http://blog.smartbear.com/devops/gif-is-dead-long-live-webm/
https://en.wikipedia.org/wiki/Video_alternative_to_GIF -
Animated Gif -> Webm tool
By lab in forum Video ConversionReplies: 5Last Post: 8th Jun 2015, 20:27 -
Help to convert an Animated GIF to AVI
By lilpotato in forum Video ConversionReplies: 17Last Post: 14th May 2013, 01:32 -
Please recommend good freeware to convert video to animated gif.
By zlmdlo in forum Video ConversionReplies: 1Last Post: 11th Jan 2012, 06:27 -
Animated Gif Maker
By budwzr in forum EditingReplies: 12Last Post: 10th Jan 2012, 12:09 -
Animated .GIF super-compression
By JJones in forum Newbie / General discussionsReplies: 5Last Post: 13th Aug 2011, 17:08
