  1. I just encoded a 5.923 second avi with AviUtl (5.923 seconds according to MediaInfo) but MPC-HC is telling me the clip is 26 seconds long. When I play it, down at the bottom right hand corner, beside the speakers symbol, it says 00:00/00:26, and when the scroll bar starts moving underneath the video, it's moving at a speed that would imply it would take 26 seconds to reach the end, but it stops after 5.923 seconds and goes back to the beginning (I have MPC-HC set on loop) because the clip is in fact only 5.923 seconds. So why is MPC-HC telling me it's 26 seconds? It says that under Properties as well.
  2. Is the audio stream longer than the video?
  3. Originally Posted by sneaker View Post
    Not according to MediaInfo. Both streams are the same, 5.923 seconds.
    EDIT: I've fixed the problem. It had to do with AviUtl. I clicked on File, SETTINGS, Import Plugin Priority, and moved L-SMASH Works File Reader to the top. That's taken care of the issue, whatever it was. I encoded the clip again and MPC-HC now says it's 6 seconds.
