Hello,
I've got a bunch of Blu-ray disks with some features I'd be interested in ripping described as "BD Live". From my understanding, these are files that aren't included on the disk but rather files which the player downloads and plays if it supports this feature. I'd be looking to encode the files and have no issues there, but I'm not sure on how to get the BD Live features on to my computer (and if there's any protection removal that's required in this process) prior to encoding.
Has anyone had any experience with this sort of thing before?
AnyDVDHD mentions bd-live removal in the changelog ( https://www.videohelp.com/software/AnyDVD/version-history#changelog from 2011 ) but I have no idea how it works.
You could also search in https://forum.redfox.bz/forums/anydvd-hd-blu-ray.53/ -
Thanks for the reply!
From read, some disks refused to open at all and that option disables any BD Live features on the disk in order to be able to play/rip disks that would otherwise be problematic. As far as I can tell, there doesn't appear to be an option or program to actually rip the BD Live content itself, only to disable it entirely.
I did find this link however: https://forum.redfox.bz/threads/how-to-keep-bd-live-while-having-blu-ray-region-code-r...ydvd-hd.23897/
It appears to be a long, but working solution. I'll have the chance to test it this weekend hopefully and if it goes well I'll confirm it here for anyone else looking to do something similar. That being said, the process does seem to involve a number of programs that I've not had any experience with and can't vouch for so there's every possibility it won't work.Last edited by thecoreyburton; 13th Apr 2016 at 09:43.
Unfortunately I was unable to test the method mentioned above as the copy of Cyberlink Power DVD I have came packaged with my drive and had insufficient credentials to access the BD Live network. If I can confirm that it works, I'll purchase a license directly from Cyberlink, I think.
FFmpeg stops while ripping live stream
By pub in forum Video Streaming DownloadingReplies: 1Last Post: 7th Jul 2015, 12:32 -
Which HDTV with the features I choose?
By Messi in forum DVB / IPTVReplies: 1Last Post: 23rd Jun 2014, 00:46 -
Best Bluray player with these features.
By dfisher052 in forum DVD & Blu-ray PlayersReplies: 15Last Post: 5th Dec 2013, 22:28 -
$185 SKNET MonsterX Live ("Portable Live Streaming Unit": HDMI IN/USB OUT)
By Brad in forum Capturing and VCRReplies: 0Last Post: 4th Dec 2012, 13:28 -
Live Video Mixing with Flash Media Live Encoder
By fuggles7 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2012, 13:08
