  1. Hi
    I get an error when I try to convert my avi:s to mpg:s.
    It's says:
    "An error occurred when audio was loaded"
    And
    "can not open or unsupported"
    Help someone???
    Would be very pleased with and answer.
    Max Q
  2. The second message (unsupported) means you do not have the correct audio codec loaded. I have noticed this a lot with friend particularly with AVIs encoded using DIVX 3.11 which seems to have its own audio codec, not included as part of versions 4, 5. Try installing DIVX 3.11 and it may solve your problem. Otherwise you need to find which audio codec it is encoded with. Try opening with VirtualDub and going to properties.
    The first error implies to me that the file is corrupt in some way. I'm not sure how to fix other than re-downloading say.
