Results 1 to 9 of 9
  1. I am using handbrake and vid coder to convert a 1280 x 720 video to a 720 x 406 video but some reasons everytime I am done converting and play it, the audio is out of sync and there is an image lag. My setting is keep aspect radio and Anamorphic NONE. Is there something else I am missing?
    Post the details from the video. Use for example Mediainfo, open video, change to View->Text and copy the video and audio details.
    It might be variable frame rate(VFR) in the video source that causes sync issuses.
  3. But HandBrake (and subsequently the HandBrake based VidCoder) are known to handle VFR just fine. Maybe the player doesn't like it, though? In HandBrake's video tab you can choose "Constant Framerate". Try that. If it's still out-of-sync try the latest HandBrake nightly. If it's still out-of-sync report a bug. Of course it's possible the source file is broken somehow and it's not easily convertible.
  4. General
    Complete name : C:\Users\ Ep11-1.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 574 MiB
    Duration : 45mn 5s
    Overall bit rate : 1 781 Kbps
    Writing application : HandBrake 0.10.0 2014112200
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 45mn 5s
    Bit rate : 1 611 Kbps
    Width : 720 pixels
    Height : 406 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 25.000 fps
    Minimum frame rate : 13.636 fps
    Maximum frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.070
    Stream size : 520 MiB (90%)
    Writing library : x264 core 142 r2479 dd79a61
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Color range : Limited
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 45mn 5s
    Bit rate mode : Variable
    Bit rate : 163 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 52.7 MiB (9%)
    Title : Stereo / Stereo
  5. Do you see anything unusual? Could it be my video codec or audio codec
  6. Above is the file that had issues.
    Below is a file that actually worked fine in the past. Everything looked kind of similar so I don't know if there is something missing in my new laptop. I kind of was able to fix the image lag by reducing 720 x 406 to something lower but the audio is still out of sync.
    General
    Complete name : C:\Users\Me\Desktop\Ch07.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 311 MiB
    Duration : 45mn 4s
    Overall bit rate : 965 Kbps
    Writing application : HandBrake 6548svn 2014112401
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 45mn 4s
    Bit rate : 798 Kbps
    Width : 720 pixels
    Height : 406 pixels
    Minimum frame rate : 8.333 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.109
    Stream size : 257 MiB (83%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 45mn 4s
    Bit rate : 161 Kbps
    Sampling rate : 44.1 KHz
    Stream size : 52.0 MiB (17%)
    Language : English
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    That is not the source file? It looks the file you converted to.
    Try sneakers advice and choose Constant framerate in handbrake under the video tab.
  8. No luck when I tried using constant frame rate. But, when I tried on a different laptop it worked. So that means something is missing on my new laptop. Do you have any recommendation which codec I should get that I might be missing.
