I'm trying to convert a movie off the net,K-PAX.It is in AVI format.When I play it as an AVI on the computer it plays perfect.I run the audio through Virtual Dub and save it as a WAV file.I then use TMPGEnc to encode the video(adding the wav for audio)using the NSTC film template,high quality as the video setting.When I watch the finished MPEG file on the computer it plays great,once in awhile the video is a little jittery but nothing dramatic.Then I burn the MPEG to CD using Nero.When I play the finished VCD in my standalone DVD player the audio sometimes gets out of sync.It usually corrects its self after 1 or 2 minutes,or sometimes if I fast forward or rewind the disc it will return to normal sync.I'm using the latest versions of all the software.Any ideas?
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
