I have a problem with my Toshiba DVD recorder. I have recorded and watched several discs over the last couple of months that I have had this unit. Tonight I rented a movie and got an error message that flashes Incorrect disc. I tried other discs that I have recorded on this unit as well as other pre recorded discs and get the same flashing message, Incorrect disc. These are standard discs, not Blu Ray that I am trying to watch. This problem just started tonight. It has been a month or so since I last used it. It was fine then. Is there anything I can do or is the unit trashed now?
Any help would be greatly appreciated.
Frank
Nothing lasts forever. What else can a dying DVD player do when it's dying other than refuse to play a DVD?
I had a similar unit once - forget the model no - but that refused to do anything unless there was a VHS cassette in the unit even tho I was not going to use the VHS.
Sounds like a dying laser but I am not that technically minded. But do try the VHS 'fix' as described above. You never know. -
My experience with modern electronics is two fold, they should not be in a poorly ventilated situation, the heat ruins the electronics, and that if used too little or heavily they fail. I have elctronics I have used regularly and they last forever, suddenly switch it on after months of no use-boom they fail.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
DVD Recorder with VHS? Magnavox? Toshiba?
By quxote in forum DVD & Blu-ray RecordersReplies: 31Last Post: 2nd Dec 2015, 19:47 -
VCR to DVD Recorder to PC
By kodec in forum Capturing and VCRReplies: 5Last Post: 11th Nov 2014, 13:28 -
SVHS MEDICAL VIDEO RECORDER or Home vcr?
By heyheyhey in forum Capturing and VCRReplies: 24Last Post: 15th May 2014, 15:16 -
Toshiba DR430KU DVD Recorder
By Frank-0-Video in forum DVD & Blu-ray RecordersReplies: 6Last Post: 15th Apr 2013, 21:33 -
Toshiba D-VKR3SU DVD Recorder-VCR Combo Question
By genx80s in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th May 2012, 05:57
