  1. I HAVE THE LATEST VERSION OF NERO AND THE PULL DOWN OPTION IS'NT THERE TO COPY DVD AS IN THIS LINK.
    http://www.vcdhelp.com/nerodvd.htm
    ANY IDEAS?
  2. The drop down will not appear unless you have a dvdwriter connected.
    May 2001
    The drop down WILL appear, whether or not you have a DVD writer attached, if you enable all options (or something like that) in the NERO preferences. I don't know exactly where it is, but peruse through the FILES > PREFERENCES menu and you will find it.
    Oct 2000
    It's called "Show all compilation Types (even ones the recorder dosn't support)".
