i was using staxrip to encode my bluray. libDcaDec reported the warning "XLL output not lossless" according to the log file.
i still had the output audio intact which was an 8-channel flac converted from the dts-hd ma.
my question is, did the warning mean something that affected the audio's quality?
That warning can usually be ignored. It can sometimes show on DTS-HD MA sources, I believe mostly when the BluRay was created using certain authoring techniques. The quality isn't affected.
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
"Lossless Audio Checker"?
By mindstormer in forum AudioReplies: 33Last Post: 28th Dec 2013, 12:24 -
ffmpeg how to "lossless" convert video codec to libx264 ? CRF & qp value
By feelart in forum Video ConversionReplies: 3Last Post: 9th Jan 2013, 20:46 -
Is the "lossless" FFV1 codec a fake? (IMPORTANT)
By Stears555 in forum Video ConversionReplies: 7Last Post: 3rd Dec 2012, 07:13 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52
