  1. Is there any way to put some drop shadow effect on watermark logo?
    in most of the filters the logo must have black background and if you make the drop shadow in white it doesnt work because the drop shadow area takes the black levels so became like a border around the logo.
    any ideas?
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Is the logo flattened to the video?
    You need to cutout the logo with an image editor. Then make the shadow.
  3. but most of the filters wants total black background behind the logo. and bmp format so the drop shadow is a bit harder that way
  4. Create an alpha mask that covers the logo and the black background. Then overlay using that alpha mask.
    logo: Name:  LOGO.png
    mask: Name:  mask.png
    Overlay with 100 percent opacity:
    Overlay with 20 percent opacity:
  5. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Most video editors I know accept 32-bit PNG images with transparency, shadows are no problem.
  6. Can you guys show me a script
    this is what I use
    a1 = ImageSource("logo.bmp").ConvertToRGB32
    mask_clip = Mask(a1, a1.GreyScale.Levels(0, 1, 10, 0, 240))
    Overlay(a1, mask=ShowAlpha(mask_clip), y=340, x=0,
     \ mode="blend", opacity=1)
    ConditionalReader("C:\timecode.txt", "ol_x_offset", false)
  7. I built the alpha mask from the logo image:
    logo = ImageSource("LOGO.png").ConvertToYV12(matrix="PC.601") # the logo
    amask = Overlay(logo, logo, x=3, y=3, mode="add") # alpha mask includes drop shadow
    ColorBars(pixel_type="YV12") # a video to add the logo to
    Overlay(last, logo, mask=amask, x=20, y=20, opacity=1.0) # add the logo
