I AM TRYING TO CONVERT THE AUDIO ON ALI MOVIE DOWNLOADED FROM EDK GUIDE. I GET AN ERROR WHEN TRYING TO PLAY IT ON WINDOWS MEDIA PLAYER (UNABLE TO DOWNLOAD APPROPRIATE DECOMPRESSOR) IF I TRY TO CONVERT IT USING VDUB I GAT AN ERROR SAYING "THE REQUESTED AUDIO IS NOT COMPATIBBLE WITH THE INPUT FORMAT" I HAVE TRIED ALL THE PREVIOUS SUGGESTIONS WITH NO JOY . I HAVE DOWNLOADED ALL THE CODECS I CAN FIND STILL NO JOY. HAS ANYONE ACTUALLY CONVERTED THIS MOVIE TO VCD? PLEASE REPLY AND LET ME KNOW HOW YOU DID IT.
THANX.![]()
Have you actually converted it to 44Khz stereo?
Try using TMPGEnc......does it for you!
I have done a DivX that was in AC3 to SVCD , no problems!"If hustling is deviance in the eyes of the lord, then in my realm he is blind"...B*Tip - Back in the day! -
first off, dude stop yelling :D
secondly, that rip if I am correct has tons of probs. the audio is a tough ac3 and the video is stretched to the wrong aspect ratio. headache ac3 I believe is what I used for the audio. there is also a guide here from our friends at doom9 that may help -
just to let everyone who has viewed this page
i have solved the problem. it goes something like this -using vdub go direct stream copy / save wav. rename the file to ac3 then convert it to wav using a the tool suggested above "head ac3". then convert to mpg using tmpgenc with the new wav file as the audio souce.
thanks for all the suggestions ,we got there in the end.
mabos22
AVIsynth -- how do I add an audio wav to a video only clip.. [SOLVED]
By vhelp in forum EditingReplies: 7Last Post: 19th Nov 2013, 06:27 -
Audio and Video synchronization *solved*
By Meriks in forum EditingReplies: 11Last Post: 4th Mar 2011, 07:11 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
(SOLVED) Need mencoder help, certain files have no audio
By Airjrdn in forum Video ConversionReplies: 16Last Post: 7th May 2008, 22:28 -
Mux avi + audio, something wrong, an issue ? (solved by myself)
By sepulcrio in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jan 2008, 12:11
