I want to digitize my collection of family videos in Video8 format and also some vhs videos. The analogue videos are in PAL format.
I have recently acquired an ATI TV Wonder 600 HD usb card and am about to install Windows 7 on my PC. I also plan to purchase Adobe Premiere Elements for video editing, and to output the video on DVD and/or mpeg4 format. I have some questions about the capturing process:
1. Does the ATI Multimedia centre function in Windows 7 ?
2. Is the ATI TV Wonder 600 HD usb card + ATI MMC able to convert analogue PAL video to PAL mpeg-2 ?
3. What software options do I have if I want to capture my analogue videos in PAL DV 25 codec in Windows 7 ?
4. Would VirtualDub and AVI capture be the best way to go with my hardware set-up?
I am grateful for any advice on my query!
If you have ATI TV Wonder 600 HD USB you can answer questions 1 and 2 by yourself by just plugging it. NLE software such as Adobe are not suitable for video restoration and cleanup, VirtualDub and Avysinth are the way to go.
3- If you have ATI TV Wonder 600 USB why would you want to buy a DV capture device? Just use what you got, DV is a lossy codec and cannot be cleaned up without doing more damage to it.
4-VirtualDub AVI with HuffYUV lossless compression with your USB capture device is the best combination if you plan on doing some restoration and editing before encoding to a popular format. -
Thank you very much for your comment!
3. I thought that the ATI TV Wonder 600 USB could capture DV, in addition to mpeg-2 and AVI. Apparently I have been mistaken in my assumptions.
4. Well, I think I will just settle for VirtualDub AVI and HuffYUV then. It seems like this is a very good option, also for my hard ware set-up, and could provide a good workflow.
Am I correct in assuming that my large AVI file in HuffYUV will be compatible with editing in Adobe Premiere Elements?Last edited by bjolester; 7th Apr 2016 at 15:36.
I don't have premiere elements, So I can't tell, But try a small capture file and load it to see how it goes.
High-end HI8 deck / camcorder to capture PAL video8 tapes
By FLP437 in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2016, 10:28 -
Need Help Choosing Capture Card, TBC, and Software/Settings for VHS/8mm VHS
By Duder_Me in forum Capturing and VCRReplies: 2Last Post: 25th Apr 2014, 09:42 -
Capturing PAL Video8 to NTSC VHS
By TrackingError in forum Capturing and VCRReplies: 6Last Post: 3rd Sep 2012, 18:02 -
Am I doing it right? Video8 and VHS Capture
By Marto2008 in forum Capturing and VCRReplies: 32Last Post: 14th Dec 2011, 05:26 -
Capturing Uncompressed Video8 and VHS-C then Compressing
By mayhampixi in forum Capturing and VCRReplies: 10Last Post: 4th Jul 2011, 11:10
