    Apr 2016
    South Africa
    Hi
    I’m a complete noob. I have compiled a video comprising several small video clips.
    When I try cut one of the source videos further, the overall compiled video length doesn’t change. The source vid is cut, but fills the cut time with either a blank screen or it holds the last image. I just want to cut one of the source vids length down, and have the entire video length change down automatically.
    Thanks in advance
    Why do you cross post? I removed your other thread.
    Nope. I do not use VSDC.
  3. Hi!
    Look the way I do cutting out: I insert several videos >> I click the one I want to cut >> then I choose the area I need to cut out >> click "Cut out fragment". As a result I see that the needed fragment became shorter, so I place it in the timeline between other fragments the way that no space is left >> I have a seamless output video.
