    Sep 2014
    Rome
    Hi
    in the timeline if i want to select several clips (in my case photos) and set the same duration , is there only way to select them , righ click and right click ->speed duration ?
    are other way to work on the timeline ? using for the example the tools?
    i want to set the same duration of (for example 20 pictures ) about 2 minutes ,and the same duration of 15 picture about 3 minutes
    i googled a lot , and seems that right click ->speed duration is the only way
    thanks
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    In Vegas, there's a Default Still length in the Preferences dialog. Premiere probably has that too.
    Sep 2014
    Rome
    hi
    but i want to change it on several different photos in the time line and not the same length
    for the same length for 10 photos , another length amount for others and so on
    thanks
