When converting a MOV file with Format Factory, I get this grey rectangle in my video. The rectangle is intermittent throughout the video, but only on the B&W film, not the color. I tried all the formats in format factory, with same result. I think it’s related to audio settings, because when I disable audio in the FF controls, the rectangle is on 100% of the video.
Attached is a screenshot
Very strange problem.
But easiest is just to try another free converter like xmedia recode, handbrake, vidcoder, etc. -
I couldn't find a subtitle option on format factory
There is an"additional Subtitle" option. The choices are:
Type: none, automatic, embedded, ansi, Unicode, utf8
I chose "none",.. no change after conversionLast edited by video-new; 5th Apr 2016 at 19:32.
Have tried Total Converter & Format Factory. Need your advice....
By steve franklin in forum Video ConversionReplies: 2Last Post: 21st Jun 2013, 18:00 -
has anyone tried FORMAT FACTORY
By hilario in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2012, 16:42 -
Avidemux & Conversion Issues with Sony MTS Format
By callmebc in forum Video ConversionReplies: 24Last Post: 11th Mar 2012, 13:42 -
Multiple questions on best file format & quality, conversion from AVCHD
By Scanderoon in forum Newbie / General discussionsReplies: 12Last Post: 2nd Sep 2011, 02:37 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22
