Results 1 to 9 of 9
  1. I have about 200 files I want to remove the Subtitle's using MKVToolnix and I wanted to do them in a batch conversion they are all MKV files and were first created as MKV's and have never been converted from one format to another and so on.
    My problem is I can not figure out how to stop MKVToolnix from merging all the files together can anyone tell me how to do this so they are not all merged into one file.
    canada
    Mkvbatch will do what you want.
  3. mkvmerge : the streams that you want to include should be checked
  4. plz ignore my pervious post.
  5. Thanks for the help guys but I'm having a new problem now with MKVbatch.
    My new problem is once I get the output path set and drag and drop all the files in to convert it's saying (mkvmerge.exe was not found at the designated path)
    can anyone tell me what's going on,I'm running Win 10 Home 64 Bit incase this help's.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Have you installed mkvtoolnix?
    Or are you using the portable version of mkvtoolnix? Then try manually set the path to mkvmerge.exe in mkvbatch in settings.
  7. I only have mkvtoolnix and mkvbatch installed do I need to install mkvmerge as well to be able to find the path to mkvmerge.
    What I don't understand is if I can use mkvtoolnix to strip out sub's from one movie at a time why don't they just include a feature with a checkbox that say's do not merge together.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Have you checked under settings and if you can change the path to mkvmerge.exe?
    It should be in the folder where you installed mkvtoolnix(like c:\program files\mkvtoolnix).
  9. DECEASED
    Jun 2009
    Heaven
    MKVmerge is part of MKVtoolnix
    I have never used mkvbatch, and if it doesn't have the feature you describe, you really should write to its author about the issue.
