Hi Friends,
I use the latest version of DVDFab 9 to rip my Blurays to my NAS (and I mean the Bluray that I have regularly purchased !...).
I have no problem with the episodes, but I get the video without any sound when I rip the bonuses : I can rip them, but I got the video without the sound ??!!
Any idea to fix this problem ??
Thank you very much,
Hi redwudz,
Below is the MediaInfo information on the ripped file : it says nothing about audio... How can i check the original file as you suggested ??
You may be right by saying that the Audio might be there in a different format, because on my previous Bluray discs (of the previous seasons), I have found many bonuses that were ripped in a .MPV format (with a lower resoution, let say 640x480 for example) that I should convert to .MOV to be properly encoded by MKVMerge. But this was related to the video track, not to the audio track, and it was the method that I used when I used Slysoft...
Since I use DVDFab 9, I do not see the video and audio tracks : DVDFab works alone and is supposed to generate the appropriate ripped video (including audio) file.
Any suggestion is welcome,
Mediainfo information of the ripped file:
Général
Nom complet : E:\BD_WORKING7\Video\STAR TREK TNG SEASON 7 DISC 6\STAR_TREK__THE_NEXT_GENERATION_SEASON_7_DISC_6.T itle13.mp4
Format : MPEG-4
Profil du format : Base Media / Version 2
Identifiant du codec : mp42 (mp42/isom/avc1)
Taille du fichier : 878 Mio
Durée : 45mn 22s
Type de débit global : Variable
Débit global moyen : 2 707 Kbps
Nom du film : STAR_TREK__THE_NEXT_GENERATION_SEASON_7_DISC_6.Tit le13
Album : STAR TREK TNG SEASON 7 DISC 6
Date d'encodage : UTC 2016-04-03 20:19:28
Date de marquage : UTC 2016-04-03 20:24:18
Application utilisée : DVDFab 9.2.3.7
covr : Unknown kind of value!
Vidéo
Format : MPEG-4 Visual
Profil du format : Simple@L1
Paramètres du format, BVOP : Non
Paramètres du format, QPel : Non
Paramètres du format, GMC : Pas de warppoints
Paramètres du format, Matrice : Default (H.263)
Identifiant du codec : 20
Durée : 45mn 22s
Durée de la source duration : 45mn 22s
Type de débit : Variable
Débit : 2 702 Kbps
Débit maximum : 12,8 Mb/s
Largeur : 632 pixels
Hauteur : 480 pixels
Format à l'écran : 4/3
Type d'images/s : Constant
Images par seconde : 29,970 (30000/1001) Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0
Profondeur des couleurs : 8 bits
Type de balayage : Progressif
Mode de compression : Avec perte
Bits/(Pixel*Image) : 0.297
Taille du flux : 877 Mio (100%)
Taille du flux source : 877 Mio (100%)
Bibliothèque utilisée : Lavc56.5.100
Coordonnées de chromaticité : BT.601 NTSC
Caractéristiques du transfert : BT.709
Coefficients de la matrice : BT.601
Menus : 3
Texte
Format : mp4s
Identifiant du codec : E0
Langue : Français
Default : Oui
Forced : Non
Alternate group : 2
Date de marquage : UTC 2016-04-03 20:19:28
Menu
Identifiant du codec : text
Durée : 45mn 22s
Type de débit : CBR
Menu For : 1
Durée de la source duration : 2722587
Nombre d'images de la source : 7
Taille du flux source : 161
Nombre d'images : 7
Taille du flux : 161
00:00:00.000 : Chapter 1
00:02:53.740 : Chapter 2
00:12:08.027 : Chapter 3
00:20:08.307 : Chapter 4
00:30:01.766 : Chapter 5
00:37:51.569 : Chapter 6
00:44:33.771 : Chapter 7
You can open the BDMV>STREAM on the BD disc to view it.
Normally the smaller/shorter duration .m2ts files are the bonuses/extras or small parts of the main movie.
The shortest files are usually previews. You should be able to play them all with VLC or a few other media players.
You should also be able to read them with MediaInfo.
But most extras/bonus video is 720 X 480 (NTSC) and the audio is just AC-3 stereo, so shouldn't be a problem to backup.
If you want to view more of the structure of a BD disc, try BDInfo. It should show all tracks and all audio and which .m2ts files are part of the main movie. -
Yes I can open BDMW>STREAM in the windows explorer, and I know that the bonuses have a smaller size than the film itself.You can open the BDMV>STREAM on the BD disc to view it.
I do not understand why, but VLC refuses to read the .M2TS files directly from the bluray disc : no pb to read the files extracted by DVDFab on a hard drive, but not directly from the disc. And DVDFab extracts the bonuses without any sound... As explained at the end of my message, VLC also refuses to read a .M2TS file when the file has been copied to the hard drive...The shortest files are usually previews. You should be able to play them all with VLC or a few other media players.
Mediainfo says nothing :You should also be able to read them with MediaInfo.
It is not always the case, and particularly with the StarTrek series, I believe that the bonus are have bit "strange" format : when I previously used Slysoft, the method for ripping was to successively use BDInfo / TsMuxer and MkvMerge, and I got a strange .MPV movie that I had to convert first to .MOV in order to merge it with the sound in MKVMerge...But most extras/bonus video is 720 X 480 (NTSC) and the audio is just AC-3 stereo, so shouldn't be a problem to backup.
Maybe it is the reason why DVDFab does not extract the bonuses correctly ? (but if a .MPV format is a strange video format, the audio format was usual...).
And i also have issues when BDInfo scans the blurawhereas I had never faced any problwhen using Slysoft (!) : look at this error
Let me show what DVDFab shows after it has read the Bluray :
And final comment : when I copy a M2TS file from the bluray to the hard disk, let say 0015.M2TS for example, VLC refuses to read it... It looks loke DVDFab does not remove the protection of the bluray ?? (whereas there was no pb at all with Slysoft).
Do you see anything strange it this display, or do you need further detail (another screen ?) to diagnose ?
Thanks for your help,Last edited by Nounours18200; 7th Apr 2016 at 13:13.
Did you not ask the folks who make this piece of software what the problem could be...?
How to contact them ??Did you not ask the folks who make this piece of software what the problem could be...?
I have post a message in this forum here: http://forum.dvdfab.cn/showthread.php?p=185536#post185536
without knowing if it is the right place to ask...
Any suggestion ?
DVDFab 8 not ripping anymore
By clashradio in forum Blu-ray RippingReplies: 32Last Post: 15th Feb 2015, 17:47 -
DVDFab No Sound when creating MP4. Change extension to M4V and sound works
By hackerjunk in forum DVD RippingReplies: 2Last Post: 5th Jun 2014, 16:04 -
Ripping movie prisoners with DVDFab
By tarzan54 in forum Blu-ray RippingReplies: 5Last Post: 22nd Dec 2013, 04:39 -
DVDFab not ripping PCM
By Mr_X2012 in forum Blu-ray RippingReplies: 1Last Post: 10th Oct 2012, 06:56 -
Ripping DVDs with DVDfab -- not the correct audio
By joylamyy in forum Newbie / General discussionsReplies: 1Last Post: 1st Oct 2012, 11:07
