Hi everyone,
I would like to extract subtitles of an M2TS file coming from my FREEBOX V6.
Below the command I typed:
As you can see, I have an unsupported codec for the Subtitle stream n°4 Unsupported codec with id 94215 for input stream 4Code:$ avprobe source.m2ts avprobe version 9.18-6:9.18-0ubuntu0.14.04.1, Copyright (c) 2007-2014 the Libav developers built on Mar 16 2015 13:19:10 with gcc 4.8 (Ubuntu 4.8.2-19ubuntu1) [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [aac @ 0x224c0c0] get_buffer() failed [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [aac @ 0x2267a80] get_buffer() failed [aac @ 0x224b6a0] get_buffer() failed [h264 @ 0x2249700] non-existing PPS referenced [h264 @ 0x2249700] non-existing PPS 0 referenced [h264 @ 0x2249700] decode_slice_header error [h264 @ 0x2249700] no frame! [mpegts @ 0x2244200] max_analyze_duration reached [mpegts @ 0x2244200] PES packet size mismatch [mpegts @ 0x2244200] PES packet size mismatch [mpegts @ 0x2244200] PES packet size mismatch [mpegts @ 0x2244200] PES packet size mismatch Input #0, mpegts, from 'source.m2ts': Duration: 00:55:00.23, start: 19624.453300, bitrate: 4608 kb/s Program 4106 Stream #0.0[0x140]: Video: h264 (High), yuv420p, 1440x1080 [PAR 4:3 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0.1[0x14a](fra): Audio: aac, 48000 Hz, stereo, fltp, 66 kb/s Stream #0.2[0x14b](qad): Audio: aac, 48000 Hz, stereo, fltp, 54 kb/s Stream #0.3[0x14c](qaa): Audio: aac, 48000 Hz, stereo, fltp, 65 kb/s Stream #0.4[0x155](fre): Subtitle: [6][0][0][0] / 0x0006 [h264 @ 0x2249f80] Ignoring NAL unit 9 during extradata parsing Unsupported codec with id 94215 for input stream 4 # avprobe output
Any idea on how to fix it ?
Below is the mediainfo to show you more information about the file M2TS generated by the FREEBOX V6:
As we can, I have 3 Text section which logic with the Teletext subtitle I originnaly have on my internet box...Code:$ mediainfo source.m2ts General ID : 4106 (0x100A) Complete name : source.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 1.77 GiB Duration : 54mn 59s Overall bit rate mode : Variable Overall bit rate : 4 609 Kbps Video ID : 320 (0x140) Menu ID : 4106 (0x100A) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=4, N=25 Codec ID : 27 Duration : 54mn 59s Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Audio #1 ID : 330 (0x14A) Menu ID : 4106 (0x100A) Format : AAC Format/Info : Advanced Audio Codec Format version : Version 2 Format profile : HE-AAC / LC Muxing mode : ADTS Codec ID : 15 Duration : 54mn 59s Bit rate mode : Variable Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz / 24.0 KHz Compression mode : Lossy Delay relative to video : -104ms Language : French Audio #2 ID : 331 (0x14B) Menu ID : 4106 (0x100A) Format : AAC Format/Info : Advanced Audio Codec Format version : Version 2 Format profile : HE-AAC / LC Muxing mode : ADTS Codec ID : 15 Duration : 54mn 59s Bit rate mode : Variable Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz / 24.0 KHz Compression mode : Lossy Delay relative to video : -104ms Language : qad Audio #3 ID : 332 (0x14C) Menu ID : 4106 (0x100A) Format : AAC Format/Info : Advanced Audio Codec Format version : Version 2 Format profile : HE-AAC / LC Muxing mode : ADTS Codec ID : 15 Duration : 54mn 59s Bit rate mode : Variable Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz / 24.0 KHz Compression mode : Lossy Delay relative to video : -104ms Language : qaa Text #1 ID : 341 (0x155)-100 Menu ID : 4106 (0x100A) Format : Teletext Language : French Text #2 ID : 341 (0x155)-888 Menu ID : 4106 (0x100A) Format : Teletext Subtitle Language : French Text #3 ID : 341 (0x155)-889 Menu ID : 4106 (0x100A) Format : Teletext Subtitle Language : French Menu ID : 66 (0x42) Menu ID : 4106 (0x100A) Duration : 54mn 59s List : 320 (0x140) (AVC) / 330 (0x14A) (AAC, French) / 331 (0x14B) (AAC, qad) / 332 (0x14C) (AAC, qaa) / 341 (0x155) () Language : / French / qad / qaa
Thanks for any help
TSmuxer problem with m2ts Subtitle
By davidecit in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Jun 2013, 19:06 -
Help converting with mkv2vob: Error is Unsupported Video Codec
By sweetnessuk in forum Video ConversionReplies: 7Last Post: 17th Jun 2012, 06:08 -
Unsupported codec (id=86021) for input stream #0.1
By noctrine in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2012, 09:13 -
m2ts to burn in Toast 11 (MAC) Issue
By Reesche in forum MacReplies: 3Last Post: 27th Sep 2011, 14:55 -
ConvertxtoDVD - Subtitle #2 (subtitle) etc Coodec Tag "mp4s" Unsupported
By Simmons in forum Video ConversionReplies: 0Last Post: 10th Jun 2011, 06:36
